ARE LOW 10'S POSSIBLE? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 02-24-2008, 02:18 AM Thread Starter
aod1992's Avatar
With my combo i'm going to be running, are low 10's possible? Heres my combo.Stock block 302, ported tw heads, anderson b31 cam, trickflow street intake, Single mpt70, turbonetics 38mm wg, knock off 50mm blowoff, 42lb injectors, 255 fuel pump, anderson pms, pmas pro tube, 70mm tb, c4 trans 4000 stall, 3:73 gear. All of this is on my 92 mustang that weighs about 3200 lbs. I know i'm limited with the stock block, but what would you change with my combo if anything to get to my et goal.
aod1992 is offline
post #2 of 2 Old 02-24-2008, 04:50 AM
Zacharyx's Avatar
I would say the first change would be to get rid of the 3.73s how high you go will be based on how tall a tire you will be running
636rwhp/576rwtq or 852/900 RSAE corrected
"And the dynos rumbled, and God spoke 'Take thine turbos, install them upon thine car, and destroy the many ricers!'
Zacharyx is offline
