cummins/holset size? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 02-10-2008, 10:18 AM Thread Starter
Unhappy cummins/holset size?
put unit off 5.9 cummins in my 89
anyone know what size it is?
anyone know what boost levels are with internal wastegate?
will i be able to tune it , 30# injectors, 190lph pump, 75mm tb, 75mm mass air, stock computer?
any help will be appreciated.
shooting for 10's
turbod89 is offline
post #2 of 6 Old 02-12-2008, 09:13 AM
Do you know if its an hx40?
or a hx35?
I think those are the common sizes
used by holset on those engines.
Rawkin is offline
post #3 of 6 Old 02-12-2008, 05:07 PM
89 might be an H1C...which is an older variant of the HX35.
It might choke up a bit because its a small turbo for a single, it would be similar to running a single T4 turbo. You probably won't be able to use the internal gate as it might not open up until 15-25 PSI...or be too small of an opening causing boost creep.
mfpmax is offline
post #4 of 6 Old 02-12-2008, 05:28 PM Thread Starter
the car is 89
turbo is 2000-2003
turbod89 is offline
post #5 of 6 Old 02-12-2008, 09:21 PM
Then the guy above me was correct about it being an HX35. It'll support 500 or so HP. Think stock are 12c/m housings, but you may want to find a larger turbine housing if possible.
Or sell it and try to get an HX40 turbo.
mfpmax is offline
post #6 of 6 Old 02-15-2008, 02:03 PM Thread Starter
Smile
thanks for info, unit already installed, will upgrade after grassroots kit is fully functional.
turbod89 is offline
