boost and compression - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 02-06-2008, 12:08 AM Thread Starter
Just wanted to see what kinda compression you guys are running and how much boost. I was looking at about 8.5-1...
justin
LoNSlo is offline
post #2 of 5 Old 02-06-2008, 03:03 AM
xr8240's Avatar
Depends on engine strength???
7.8 comp and 18Lb boost...
@ 650 rwhp...
xr8240 is offline
post #3 of 5 Old 02-06-2008, 05:09 AM
Zacharyx's Avatar
Also depends on what kind of off boost performance you want, and how much power you want to make overall
636rwhp/576rwtq or 852/900 RSAE corrected
"And the dynos rumbled, and God spoke 'Take thine turbos, install them upon thine car, and destroy the many ricers!'
Zacharyx is offline
post #4 of 5 Old 02-07-2008, 10:52 PM Thread Starter
Im looking to make about 8-900 horse with my coupe. Ill be putting a cobra cast iron block, forged internals, and about 8-1 comp. Also was looking at about 20lbs...
LoNSlo is offline
post #5 of 5 Old 02-08-2008, 07:02 AM
xr8240's Avatar
That'll do it on a 4v head....Even 8.5 with good ecu....
Back pressure through turbine / exhaust kept in control to limit detonation..
xr8240 is offline
