Turbo kit help. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 02-05-2008, 12:42 AM Thread Starter
Turbo kit help.
So anyways, this is going to be my first Mustang.
My father has a 351W with a Vortec T-Trim, and hes been trying to talk me out of my turbo Hayabusa.
Its a 1595 stroker, built head, with a GT-28R. Putting down 372HP.
I was thinking about a 351W, Carb'ed, and a decent sized single turbo... any really decent kits out there? I'm not the greatest with fabrication work, and hopefully you have some advice on the engine build.
Thanks.
cmkfx is offline
post #2 of 10 Old 02-05-2008, 02:37 AM
Zacharyx's Avatar
B&G makes 351 kits, I am not sure he has a carb bonnet though
636rwhp/576rwtq or 852/900 RSAE corrected
"And the dynos rumbled, and God spoke 'Take thine turbos, install them upon thine car, and destroy the many ricers!'
Zacharyx is offline
post #3 of 10 Old 02-05-2008, 03:55 AM
lethl-lx's Avatar
Here you go Check out Quicktime Turbos . This a kit that was just done in the last few weeks .
The kit`s fit Great and Newt `s customer service is second to none .. give him a call . The link to his web site is in my Sig .
This is a 351 base motor that is a blow-thru ..
https://www.corral.net/forums/showthread.php?t=989844
http://www.youtube.com/watch?v=jij1H7WBZaw
91LX Vert 306 Winsor Sr. heads ,42lb inj , 70mm Accufab TB Typhoon intake ,TFS Stage 1 cam
70mm Turbo kit
lethl-lx is offline
post #4 of 10 Old 02-05-2008, 07:56 AM
Go with Quick Time....
1988notch is offline
post #5 of 10 Old 02-05-2008, 01:19 PM
How much power are you looking for? Budget?
65 Mustang
68 Barracuda 440
boostdidfox is offline
post #6 of 10 Old 02-06-2008, 12:57 PM Thread Starter
I have roughly 10k to spend.
cmkfx is offline
post #7 of 10 Old 02-06-2008, 02:47 PM
Then go big! There are many companies out there that make great products but it comes down to what you like. I would start by looking at the power you want to put down and what turbo is right for your set up. Some companies I would suggest would be QT (as stated above), BG ( I had one on my 351w), HP has some good stuff as well but they are a little pricey. How much power are you looking to put down?
65 Mustang
68 Barracuda 440
post #8 of 10 Old 02-06-2008, 11:29 PM Thread Starter
I'm looking to put down atleast 600-700HP. I wanted to do the QT T-76 blowthrough for a 351!
As far as engine setup, I don't know how I'm going to do yet.
cmkfx is offline
post #9 of 10 Old 02-07-2008, 02:18 AM
we just did a pt78 on a 393 stock block engine non intercooled on 14lbs of boost it went 711rwhp and 719rwtq. If you need anything give us a call be more than glad to help you out.
thanks
Newt-Rod is offline
post #10 of 10 Old 08-05-2008, 02:43 PM
Wildstreet's Avatar
Trader Feedback: (60)
kit
I can build you a kit. This is one I am finishing right now on a 351-W
http://www.theturboforums.com/smf/in...topic=113670.0
Wildstreet is offline
