Best gear ratio with turbo fox - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 36 Old 01-27-2008, 03:03 PM Thread Starter
What is a good all around gear ratio for a turbocharged fox mustang with stock cam,tfs heads, cobra intake, t-5 trans.Car is street driven only.
Brian 90 is offline
post #2 of 36 Old 01-27-2008, 03:58 PM
Trader Feedback: (30)
3.27
-'90 Mustang LX Coupe 5.0 SSP. 83 DSO US Gov't Issue. H/C/I Track toy
93Krwy is offline
post #3 of 36 Old 01-27-2008, 05:49 PM
♥ wendy ♥'s Avatar
i have a 3.27 in mine. really lets you grab hold of the top end.
1991 lx turbo notch
♥ wendy ♥ is offline
post #4 of 36 Old 01-27-2008, 06:04 PM
Thunder5.0's Avatar
I have 73's on and it gets sideways pretty easily. I may switch over to 55's.
Thunder5.0 is offline
post #5 of 36 Old 01-27-2008, 07:05 PM
428GT's Avatar
3.31's here
89 GT--428 Dart Block 9.1:1, AFR 225's, Edelbrock Super Victor EFI ,Bullet Cams turbo cam, Accufab 90mm TB, TH-400, Ultimate Converter, AEM EMS, twin GT4088's
428GT is offline
post #6 of 36 Old 01-27-2008, 07:12 PM
rob
rob's Avatar
Trader Feedback: (23)
contrary to turbomustangs, one size does not fit all.
your whole combo dictates your gear.
fwiw, i run a 3.73 and nearly hit the rev limiter with 28" tires. i think its perfect for my combo till i plan to go even faster.
rob is offline
post #7 of 36 Old 01-27-2008, 07:12 PM
Trader Feedback: (15)
Originally Posted by Brian 90 View Post
What is a good all around gear ratio for a turbocharged fox mustang with a t-5.Car is street driven only.
These!!
fivonut is offline
post #8 of 36 Old 01-27-2008, 09:56 PM Thread Starter
fivonut
I have a set of 327,355,373.
Brian 90 is offline
post #9 of 36 Old 01-27-2008, 10:05 PM
93hulk's Avatar
I always had 3.27's on a 28 inch tall tire. Remember turbos love to be loaded so the a 3.27 with help hold the car in its power band longer.
My Stable:
76mm Turbocharged 93 coupe, Vortech blown 94 gt, Paxton blown 89 lx hatch
93hulk is offline
post #10 of 36 Old 01-28-2008, 05:00 AM
nesluopetan's Avatar
3.55 is the best overall down low and top end gear ratio in my opinion
1996 Ford Mustang SVT Cobra
Vortech Supercharger w/ Aftercooler
12lb Boost 519.97 RWHP 11.40 @ 118 1.60 60' @ 4600 FT
nesluopetan is offline
post #11 of 36 Old 01-28-2008, 07:49 PM
I got 3:31, wish I had 3:08s
toutlaw is offline
post #12 of 36 Old 01-28-2008, 10:32 PM
3.27 in there with lotsa miles, but still work great. Have some new 3.31s that'll probably go in with the new diff.
Mike
'00 Mustang GT Vert: Long gone.
'83 Mustang GLX: T-tops,EFI 5.0L/T-5/8.8 transplant,Ebrock heads/int,F303,15psi Turbo,TwEECer R/T,3.27s,Cobra brakes...
Y2KStangGT is offline
post #13 of 36 Old 01-28-2008, 10:40 PM
428GT's Avatar
Me too!!
428GT is offline
post #14 of 36 Old 01-29-2008, 10:04 AM
fred50stang's Avatar
Had 3.73 then put in a 3.55 and considering putting in 3.27's.
fred50stang is offline
post #15 of 36 Old 01-29-2008, 10:07 AM
I have 4.10 with AOD and 26" tire. Do you think I will be fine?
slickrick40217 is offline
post #16 of 36 Old 01-30-2008, 12:06 AM
silver89coupe's Avatar
i have PA super comp C4 transmission with 3:08 (good all around gear for turbo)
(still wish i had taller gears for highway driving)
if i install a gear vender i would go back to 3:27 or 3:55
silver89coupe is offline
post #17 of 36 Old 01-30-2008, 08:54 AM
mbricher's Avatar
I plan on pulling my 3.73 out and going with a 3.27 once I get my car back together.
1990 Mustang GT
Dart IE 363, PT78 HPS, Built 4R70W, BS3, BBRC Fuel system, TeamZ, ect.....
Tuned by Bob Kurgan
mbricher is offline
post #18 of 36 Old 01-30-2008, 11:34 AM
Like most have said, a 3.27 or a 3.31, which ever is cheaper for you to get. Now if you had an automatic and/or a bigger motor then I'd maybe lean towards the 3.08s some have said. I would not do a 3.73 or 4.10 but maybe would consider a 3.55
post #19 of 36 Old 01-30-2008, 11:48 AM
qikazz's Avatar
I had 3.73, then went to 3.55. Had that in the car for a while. Now I'm running 3.27 in the car. This is with an AOD. Man, it really loafs down the highway in overdrive
qikazz
'91 mod motor, turbocharged notchback, mid-8s... (SOLD)
'91 331ci GT, twin 76mm turbos, hopefully mid-7s...
'03 Evo, 2.0L, 68mm turbo, AWD street terror, mid-9s
qikazz is offline
post #20 of 36 Old 01-30-2008, 12:11 PM
Steed93's Avatar
If you are gonna race your car, you want the gear ratio that's gonna put the engine near redline going thru the traps in 4th gear. In my case with 3.55's and 26" slick, I go thru the traps at about 5900 rpm.
1993 LX hatch
11.21 @ 124
480 whp, 520 wtq (10 psi)
Steed93 is offline
post #21 of 36 Old 01-30-2008, 12:16 PM
Yeah, but since he said it is street driven only, then none of that matters
post #22 of 36 Old 01-30-2008, 04:46 PM
I had 3.73's and that was way to much gear. I dropped back to the stock 3.08's which was perfect w/ the t-5 (3.35 first gear) Now that I've swapped to the t.56 (2.97 first gear) I'm kinda wishing I had a 3.27 or 3.31 as first gear is a little doggy. Not awful, just not sure how its gonna act at the drag strip.
Will
Teal94GT50 is offline
post #23 of 36 Old 01-31-2008, 12:52 AM
slo5.0.'s Avatar
3.27 here
slo5.0. is offline
post #24 of 36 Old 01-31-2008, 02:08 AM
ARCANGL's Avatar
Trader Feedback: (76)
way too much gear for a turbo
ARCANGL is offline
post #25 of 36 Old 02-01-2008, 06:51 PM Thread Starter
I think I will go ahead and use my avail 327 gear.Going to be a totally different feel from 373 back to 327 gear.
Brian 90 is offline
post #26 of 36 Old 02-02-2008, 08:44 AM
mbricher's Avatar
Same thing I am doing. I think it will make the car a lot more fun on the street!
1990 Mustang GT
Tuned by Bob Kurgan
mbricher is offline
post #27 of 36 Old 02-02-2008, 09:17 AM
pkstang's Avatar
Trader Feedback: (161)
exactly!
pkstang is offline
post #28 of 36 Old 02-02-2008, 12:16 PM
Angry_Man's Avatar
On my stick single hifi car I ran 3:55's for a while at 400 to the wheels. Went to 3:08's and it was ok on the street. Then tried the 3:27's and I think they are close to perfect.
My other car has a incon kit with an AOD. 3:55's and a 26 tire I am not real happy so far. Trying a new TC soon and will know more but I think a 3:27 is in my future.
Angry_Man is offline
post #29 of 36 Old 02-03-2008, 12:36 PM
rob,
I will take it one step further, ones whole combo(regardless of power added selection) and their goals and preferences is what dictates what gear to go with. For example my brother has a HCI 93 GT that he drives daily and it has 3.73 gears in it and he can not stand those gears. Whether they are perfect for his car to go down the 1/4 or to street race or whatever else, they are far from perfect for him. If I was doing another fox body to be solely a street car with a turbo or even a supercharger, I would get a 3.27 or a 3.31, just simply because I prefer how those drive daily. My biggest concern would be how the car behaves for every day driving which is what 95% of its use would see. It would be silly for me to build a car for the other 5% of the time where I might be doing WOT blasts, racing someone or whatever else.
Of course my daily drive is what dictates all of that and I drive 70-120 miles every day and while a lot of that is on the freeway, the freeway sometimes is stop n go. When I had a car with 4.10 gears for that drive, I hated it. When I had a car with 3.73 gears for that drive, I did not really care for it. When I had a car with 3.55 gears for that drive, I had no complaints. When I had a car with 3.31 gears for that drive, I wondered why I ever dealt with the other gear ratios. The whole reason my gearing changed between them is because my first Fox Body had 3.55 gears and then I swapped the entire rear end and ended up with 3.73 gears which later I changed back to 3.55. Then my second Fox Body had 4.10 gears and then I swapped gears to 3.31s due to the price of them new at the time.
A lot of other people just care about how fast the car is and will live with any comprises they have to live with in order to get the most speed.
post #30 of 36 Old 02-11-2008, 04:47 PM
Erich's Avatar
I had 3.27 and the were perfect for street and strip with a 26 inch tire on my combo. I broke the rear and pieced some stuff I had together. Now running 2.73s. These are horrible. Talk about loafing down the highway lol.
Erich
Erich is offline
post #31 of 36 Old 02-14-2008, 11:26 AM
97SVT's Avatar
3.27s here switching to 3.08 with new setup & 28" tire
1967 Mustang Coupe
1990 Mustang GT Turbod DD
1987 Mustang GT Turbod-9.75 @ 140mph gone but not forgotten
97SVT is offline
post #32 of 36 Old 02-18-2009, 11:27 PM
jturmanator's Avatar
anyone got a set of 327's?
jturmanator is offline
post #33 of 36 Old 02-22-2009, 08:46 AM
Thunder5.0's Avatar
I got rid of the 73's and went with the 327's. Feels a lot better now. It still comes out hard and stays in the power band longer.
post #34 of 36 Old 02-22-2009, 09:03 AM
Javaking's Avatar
3.27's here
637/720 14.5psi pump gas
Mustang Dyno/Tuned by EFI Logics
Hellion systems
Javaking is offline
post #35 of 36 Old 02-22-2009, 12:50 PM
NC STANG GUY's Avatar
Trader Feedback: (176)
I went from 3.73's with my H/C/I Vortech setup to a 3.27 when I went to the BG kit.
Even with the blower I hated how useless 1st gear of the T-5 was with that much power and a 3.73 rear.
This was with running 275/40/17 rear tires which are around 25.75" tall or so.
NC STANG GUY is offline
