HP owners, any problems with crossover? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 21 Old 01-02-2008, 11:32 PM Thread Starter
WhiteSSP's Avatar
I just purchased a used HP Stage 1 kit locally and I'm just wondering if any HP owners have had any issues with the slip joint on the crossover being used instead of a flex joint.
I'm just wondering if its worth the money buying a flex joint and having it welded on while its out or if it'll work perfectly fine with the slip joint.
WhiteSSP is offline
post #2 of 21 Old 01-03-2008, 11:22 AM
fred50stang's Avatar
No problems with my kit. It doesnt leak either.
fred50stang is offline
post #3 of 21 Old 01-03-2008, 12:47 PM
get the flex. why doesnt it have one from the factory?
forst1 is offline
post #4 of 21 Old 01-03-2008, 01:01 PM
Nothing really wrong with using a slip joint
but the flex connector is definitely better if you dont mind messing with it.
r.barn is offline
post #5 of 21 Old 01-03-2008, 03:21 PM
Blackfive0's Avatar
Trader Feedback: (62)
I have never had a problem with mine. No need to waste you time with the flex joint
Blackfive0 is offline
post #6 of 21 Old 01-03-2008, 03:22 PM
Keep the slip joint and put an exhaust clamp over it if you are worried about it like I was. It hasn't leaked on my kit yet.
-Jason
db1994 is offline
post #7 of 21 Old 01-03-2008, 05:44 PM
rob
rob's Avatar
Trader Feedback: (23)
hp is junk! who sold you that crap
rob is offline
post #8 of 21 Old 01-03-2008, 07:52 PM Thread Starter
WhiteSSP's Avatar
I dunno, some cop with a junky old fairmont
WhiteSSP is offline
post #9 of 21 Old 01-03-2008, 07:52 PM Thread Starter
WhiteSSP's Avatar
dp
WhiteSSP is offline
post #10 of 21 Old 01-03-2008, 08:57 PM
TurboJunky's Avatar
x2.
no issues here. Tell you the truth if my kit had a flex joint I would probably cut it out and make it a slip joint. I think that K.I.S.S. applies here.
Jess
TurboJunky is offline
post #11 of 21 Old 01-03-2008, 09:07 PM Thread Starter
WhiteSSP's Avatar
If I have nothing to worry about, all that does is save me money. Thanks everyone.
WhiteSSP is offline
post #12 of 21 Old 01-03-2008, 10:28 PM
bikewiz's Avatar
Trader Feedback: (18)
Mine was a PITA to install. I dunno if my headers were made wrong, but i have to pretty much line up the pipe and tighten up one side and then jack the pipe up 1/4" or so to make the other side's flanges meet up to get the other v-band on. If it had a flex joint, this wouldn't be a problem.
I used a stainless band clamp on the x-over with a thin layer of copper RTV to ensure no leakage.
HP is junk, period. They have a good design that makes great power, they just need to be bought out by a company who cares about quality and customer service.
Matt
bikewiz is offline
post #13 of 21 Old 01-03-2008, 10:47 PM Thread Starter
WhiteSSP's Avatar
Luckily I didnt have to deal with HP
WhiteSSP is offline
post #14 of 21 Old 01-03-2008, 11:13 PM
bikewiz's Avatar
You have no idea how lucky you are! I ordered my kit October of '06 and didn't get all the stuff until spring of '07.
They did mess up and send me 2 turbine housings however. I have a new in box, Jet-Hot coated .91 A/R T4 turbine housing (standard with HP stage 2 turbo for a 347ci motor) that I can sell you if you need it.
Matt
bikewiz is offline
post #15 of 21 Old 01-10-2008, 04:52 PM
cobra29svt's Avatar
Trader Feedback: (15)
I see you're in Norfolk. Im in Richmond and in the process of finishing my HP kit. Good luck w/ yours.
95 cobra 90 gt
hp turbo kit black-on-black
systemax heads and intake
stupid little bolt-on's
cobra29svt is offline
post #16 of 21 Old 01-10-2008, 05:07 PM Thread Starter
WhiteSSP's Avatar
Thanks. I'm still in the planning/buying stages, I'm hoping to have it done before 2009, but I'm not sure what I'm doing about a second vehicle right now.
WhiteSSP is offline
post #17 of 21 Old 01-10-2008, 08:43 PM
P.F.M's Avatar
I have a HP kit with the slip fit and it works fine.
92 notch Black on black with Boost
P.F.M is offline
post #18 of 21 Old 01-12-2008, 02:22 PM
The slip fit on my HP kit fit just fine also.
pete's89gt is offline
post #19 of 21 Old 01-12-2008, 02:28 PM
bikewiz's Avatar
I must of just had a poorly made header or crossover from them. Mine didn't line up at all. It was the same problem when I had it on my stock longblock, and now on my Dart/AFR setup.
Matt
bikewiz is offline
post #20 of 21 Old 01-17-2008, 08:44 PM
shelby6782's Avatar
Trader Feedback: (26)
stay away from hp took me a year to get the right stuff and im still missing parts that i have to pay out of my pocket after i spent $7000 to them nice parts crappy service.
2013 DIB CS/GT- Boss Intake, MBRP Long Tubes, MBRP Offroad H-Pipe, and MBRP Race cat back, JLT CAI, SCT w/ Lund tunes and custom dyno tune from DGR performance, 3.73, MGW Shifter, UPR oil separators and AMR Gloss black 18's, 421whp and 370wtq
shelby6782 is offline
post #21 of 21 Old 01-18-2008, 12:46 AM Thread Starter
WhiteSSP's Avatar
Pssst....I've already got the kit, I bought it used.
WhiteSSP is offline
