Garrett GT4718 on 4.6 2V,is it too big? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 12-26-2007, 09:13 PM Thread Starter
tomyb1976's Avatar
GT 4718-88 turbine .96 AR.Will I be able to spool it up by 4000-4500?
It a build engine,ported heads,cams,bigstuff3,C4 trans.
What do You guys think?
I'm not trying to break any records,doing it just for plain fun and I got a turbo for close to nothing.Tom
forged 2V,BW 80mm turbo
tomyb1976 is offline
post #2 of 7 Old 12-26-2007, 11:45 PM
Will Evers's Avatar
I use this turbo on a 327ci pushrod motor and on the Tb at 4000 RPM, it makes 24lbs which is plenty to leave with.
Will Evers is offline
post #3 of 7 Old 12-26-2007, 11:49 PM
xr8240's Avatar
Hope your rotating assembly is good...
Good for 700 to 1200 h.p....
xr8240 is offline
post #4 of 7 Old 12-26-2007, 11:50 PM
Will Evers's Avatar
Mine?
post #5 of 7 Old 12-26-2007, 11:55 PM Thread Starter
tomyb1976's Avatar
Engine has a good rods,pistons,crank etc..
I don't really care if it breaks,I have a new bullet on order with modular performance.
I'm just loking to kill some time during the winter and fab up the turbo kit.
I got a good deal on turbo,so why not use it?
post #6 of 7 Old 12-27-2007, 12:03 AM
use it! have some fun!
2vSlowness is offline
post #7 of 7 Old 12-27-2007, 01:45 AM
xr8240's Avatar
Originally Posted by Will Evers View Post
Mine?
No mate with the good ole pushrods its the block !!!
Oh!! Do I know about it !!!Iron Eagle fixed that !!!!
xr8240 is offline
