blow thru or draw thru - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 17 Old 12-24-2007, 10:16 PM Thread Starter
Trader Feedback: (250)
what are the advantages and disadvantages of either a blow through or a draw through mass air meter on a twin turbo kit? its the last thing i need to get to finish my build..should be making in the neighbor hood of 800 at the wheels if it makes a difference. also i would like to see some pics if anyone has any of their twin turbo setup's on a pushrod motor in a fox!
thanks
ken bridgman
717-449-1426
[email protected]
eighty8gtfiveo is offline
post #2 of 17 Old 12-24-2007, 10:32 PM
mbricher's Avatar
With twins you are probably limited to only blow through.
1990 Mustang GT
Dart IE 363, PT78 HPS, Built 4R70W, BS3, BBRC Fuel system, TeamZ, ect.....
Tuned by Bob Kurgan
mbricher is offline
post #3 of 17 Old 12-24-2007, 10:38 PM Thread Starter
thats kind of what i was thinking.
thanks!
ken
post #4 of 17 Old 12-24-2007, 10:40 PM
Yeah, you would have to do a blow thru on a twin set-up
You couldnt have 2 draw-thru's - one before each turbo
From what I gather blow thru's can have problems with reading
correctly if you dont put enough straight pipe before and after
them. where as a draw-thru gives more precise readings.
I think they both work equally well if installed properly.
r.barn is offline
post #5 of 17 Old 12-25-2007, 10:35 AM
make sure you do the bypass on a draw-thru . . .
streetfalcon is offline
post #6 of 17 Old 12-25-2007, 02:18 PM
fwiw i'm using a blow though and never had a prob. BUT, I do have about 6" or more of straight tube before the MAF
L&StangNC is offline
post #7 of 17 Old 12-27-2007, 11:42 PM Thread Starter
how much straight tubing is needed before and after the MAF?
L&StangNC can i see some pics of your setup?
email to [email protected]
thanks
ken bridgman
post #8 of 17 Old 12-28-2007, 01:11 AM
StreetLethal's Avatar
6" is a good amount of straight pipe! That is how we do all the higher boost cars! Even when we do have the option to go draw through! You will most likely need a mafia even if you run a big air 3000 sct meter simply because the meter will peg way sooner when it is blow through! Good Luck Terry
StreetLethal is offline
post #9 of 17 Old 12-28-2007, 10:38 AM
red89coupe's Avatar
Trader Feedback: (31)
yep thats what I did. I run a 3in PMAS pro tube made for blow thru only. It wasnt easy but I put the MAF in the middle of about a 18in long straight pipe.so I 6in before the meter, the meter itself, and then another 6in after it and I have had NO issues.
let me know if you want pics and I will email them.FYI its a single turbo setup tho.
red89coupe is offline
post #10 of 17 Old 12-29-2007, 02:12 AM Thread Starter
red89coupe feel free to send pics to my email address, along with anyone else who wants to share!
thanks
ken
[email protected]
post #11 of 17 Old 12-29-2007, 05:37 PM
thanks
ken bridgman
I have tuned many Turbo Cars running Maf Setups! It is very important to have atleast 3-6 inches straight pipe before the Maf. It can be a driveability nightmare! if not.
1995 GT ON3 Turbo Build~
t-trim 93 is offline
post #12 of 17 Old 12-29-2007, 05:37 PM
thanks
ken bridgman
post #13 of 17 Old 12-30-2007, 02:25 AM Thread Starter
thanks for the heads up t-trim! ill make sure i have as close to 6 inches as possible before and after the MAF. now since im new to the blow thru maf's, i dont really know any companies that make them?!? like does pro-m make them or is there something better that i should look into?
thanks
ken
post #14 of 17 Old 12-30-2007, 11:15 AM
U.S. Air Force RETIRED
Matt Grieve's Avatar
Trader Feedback: (88)
thanks
ken
JD's Performance sells PMAS meters, they have a drop down menu where you can select the calibration, injector size, blow thru etc...and like t-trim said make sure you have 6 inches or so straight before the meter...sounds like its gonna be asick street car, good luck
1990 Mustang GT
2004 Mystichrome Cobra
2015 Mustang Ecoboost
2015 RAM 2500 Cummins
Matt Grieve is offline
post #15 of 17 Old 12-30-2007, 11:26 AM
I know PMAS offers blow through meters which are custom order.
Brian 90 is offline
post #16 of 17 Old 12-30-2007, 01:13 PM Thread Starter
thanks guys!
post #17 of 17 Old 12-30-2007, 09:04 PM
he could use a bov between the turbo and the maf..
Turbomustang
Mesarina is offline
