New best time w/HP turbo - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 12-16-2007, 11:13 PM Thread Starter
fred50stang's Avatar
Thumbs up New best time w/HP turbo
It was the last day for test/tune at our 1/8 mi. track here in FL. Great day to be racing also, 50 degrees and not a cloud in the sky. Made a few runs with only 8lb of boost, went a couple 7.50s'@100. Turned up the wick to 16lbs of boost, this is on stock 16in stock pony wheels with Mickey Thompson drag radials on back, t-5 5 speed, and pump gas. Here are the results...(eight mile).
1.73 - 60ft
4.65 - 330ft
6.940 - 1/8
110.62 -mph!
Not the fastest car around, but I am very happy!
fred50stang is offline
post #2 of 12 Old 12-16-2007, 11:31 PM
greygoose's Avatar
Trader Feedback: (36)
1.73 - 60ft
4.65 - 330ft
6.940 - 1/8
110.62 -mph!
Nice numbers!
How do you leave with the 5-speed? i.e. two step, rpm?
greygoose is offline
post #3 of 12 Old 12-16-2007, 11:42 PM Thread Starter
I take it up to about 5K, and rapidly, yet sliping it a little bit I let the clutch out, then I play the church organ for the next 6.94 seconds. I would have a better time if I could leave the line with some boost.
I have a two step, I just haven't figured out a good place to wire it yet. A finger button on the shifter wont work for me, too much action. I just need to get under there and wire up a switch on the clutch some how.
post #4 of 12 Old 12-17-2007, 10:14 AM
greygoose's Avatar
I have a two step, I just haven\'t figured out a good place to wire it yet. A finger button on the shifter wont work for me, too much action. I just need to get under there and wire up a switch on the clutch some how.
Yeah, my buddy has his wired up to when you let off the clutch it disengages the two step. I think he just has a micro switch under the clutch pedal.
Man your MPH is kick ass.........whats that good for in the 1/4 130+?
post #5 of 12 Old 12-20-2007, 01:51 AM
lo fo do's Avatar
nice
Good job.I started with the stg 1 kit also. Went 11.87 my fist year out.Then sold the 60mm turbo and got a pt 76s and went 8.93 @150.Now im looking to install a pt88.So good luck
lo fo do is offline
post #6 of 12 Old 12-20-2007, 12:29 PM
billyNOTnice's Avatar
Trader Feedback: (80)
fred what gears are you running?
----------Dart 363 Turbo 93 Cobra #3193----------
--------------Magnum T56--------------
billyNOTnice is offline
post #7 of 12 Old 12-20-2007, 02:52 PM Thread Starter
3.55 is what's in there now. I have a set of 3.27's I will probly stick in there over the florida cool spells, or winter for all the northern folk.
post #8 of 12 Old 12-21-2007, 12:31 PM
red89coupe's Avatar
Trader Feedback: (31)
what size DRs are you running?? I cant launch with ANY boost or higher then 3500 rpm or it just spins. I cant even use the 2step to launch at 3500 cuz it builds too much boost and spins lol
here is a diagram (thanks to C MY 4D) on how to do the 2step so it only comes on the first time you push the clutch (when staged) in and not when you shift every gear. I tried JUST the clutch switched and it sounded like ass when I shifted and I didnt like it on my cruise control or windshield washer button lol
[/QUOTE]
NICE numbers, what were your 60 ft times with "low" boost??
red89coupe is offline
post #9 of 12 Old 12-21-2007, 03:38 PM
Trader Feedback: (38)
Nice numbers!
solozx10r is offline
post #10 of 12 Old 12-21-2007, 09:31 PM Thread Starter
NICE numbers, what were your 60 ft times with "low" boost??[/QUOTE]
255/50/16, I have a set of 28x10 slicks and skinnies on Bogarts. I want to get my anti-roll bar welded in, and tq boxes welded up before I do damage with that.
my 60ft times with 8lbs was, 1.94,1.87
Thanks for the schematic, that something I'm going to work on. That and look at getting a Mcleod street twin. I dont think the spec 3 is going to hang very much longer.
In race trim, with the Bogarts...
post #11 of 12 Old 12-22-2007, 01:59 AM
nice numbers and nice car!!!
Turbomustang
Mesarina is offline
post #12 of 12 Old 12-29-2007, 05:44 PM
DaOnE51T's Avatar
nice mph!!!
Bad Intentions Motorsports, The secret is the tune!!!
DaOnE51T is offline
