Boost&Turbo Q'S 62-1 .81AR - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 12-10-2007, 06:53 PM Thread Starter
Looking at installing a 62mm turbo .81AR .I have a 90lx with 40k mile 5.0 with stock cam,1.7 rockers, tfs heads cobra intake,5sp 327 gear.
What rpm will turbo start to make boost.
What rpm will I see the max of 10psi of boost.
Life expectancy of a 62mm turbo with or without ball bearing.
Brian 90 is offline
post #2 of 7 Old 12-11-2007, 08:20 PM Thread Starter
I talked to a guy today about a 62mm.81a/r turbo with my combination.
He said it would start boost at low 2000 range and provide full boost at low 3000 rpm.What do you guys think.
Brian 90 is offline
post #3 of 7 Old 12-12-2007, 08:58 PM
red89coupe's Avatar
Trader Feedback: (31)
That sounds about right. That turbo on my stock motor spools just a tad later. not much. Its hard to tell when driving.
red89coupe is offline
post #4 of 7 Old 12-14-2007, 04:37 PM
blown8950's Avatar
Sounds right to me as well. I see full boost by 3K.
1989 LX: Vortech YS-Trim blown DSS 347, Stage 3 Twisted Wedges, Holley Systemax 2, AFM B-451 cam, AFM Power-Pipe, AFM PMS, 80mm Pro-M, Aeromotive 1000 hp fuel system, Precision Turbo 65 lb/hr injectors, UEGO 1000 Wide Band O2, MSD 6BTM and Distributor, 33-spline Moser axles and spool, Bogart Drag-On Stars, UPR Chromemoly K-member and A-Arms, Kooks 1-7/8", Dr. Gas, 130 amp alt, etc.
1991 GT Convertible: stone stock, PA AOD, Edge Converter, 62mm Turbo, 397 rwhp, 458 lb./ft rwtq @ 8 psi
blown8950 is offline
post #5 of 7 Old 12-14-2007, 04:57 PM
slowblown5.0's Avatar
For what its worth you might consider the .68 AR Should spool a little quicker for a street car.
Again it is hard to tell when driving but I wanna say im seeing boost at or before 2000 and full boost by 3000.
73 CJ5 408W, 4sp Toploader, 9" locked up front and rear
03' MG Cobra, 2.9 whipple, T56 Magnum, Mcleod RXT, 591/540
slowblown5.0 is offline
post #6 of 7 Old 12-22-2007, 08:59 AM
+1 on the .68
forst1 is offline
post #7 of 7 Old 12-22-2007, 04:50 PM
rob
rob's Avatar
Trader Feedback: (23)
that turbonetics with the .81 spools super fast, you'll like it.
rob is offline
