Not sure what BOV spring to get....... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 12-04-2007, 12:41 PM Thread Starter
I've been stumped a bit over this one. My question is this, my engine vacuum hangs in the 17/18" range at idle.
From Tial:
-18 and -21 in/Hg Un-painted -11 Psi (-22 in/Hg )
- 14 and -17 in/Hg White -9 Psi (-18 in/Hg )
So my vacuum sits right in the upper end of the 9psi spring, and the lower range of the 11 psi spring, which do I get? If I go with the 9 psi spring, won't the BOV be cracked open a little some times (sucking unfiltered air in the engine)? Or if I go with the 11 psi spring, won't the valve open a little late after letting off the throttle?
87'GTstang is offline
post #2 of 4 Old 12-10-2007, 11:36 AM Thread Starter
No one has ever had a turbocharged car and had an engine vacuum right in between two spring ratings and had to decide on which one?
post #3 of 4 Old 12-23-2007, 10:29 PM
♥ wendy ♥'s Avatar
Go with the 11lb... We have the same problem... Works fast
1991 lx turbo notch
♥ wendy ♥ is offline
post #4 of 4 Old 12-28-2007, 01:09 PM
slowblown5.0's Avatar
I used a mity vac vacuum pump and tested mine on the bench. The spring in mine was opening waaaay late for what it was advertised so I ended up cutting a few coils off of mine. Its just barely hanging open at 17hg---and if you have a blow through that is metered air you are sucking in--its just unfiltered
73 CJ5 408W, 4sp Toploader, 9" locked up front and rear
03' MG Cobra, 2.9 whipple, T56 Magnum, Mcleod RXT, 591/540
slowblown5.0 is offline
