questions for people who have quicktime turbo kit's - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 12-02-2007, 06:27 PM Thread Starter
have you guys had any problems with your kits? how much boost do you guys run with yours.
jeffs89gt is offline
post #2 of 12 Old 12-02-2007, 07:12 PM
Trader Feedback: (38)
So far no problem's with the kit or anything, i am on the wastegate spring waitng to be tuned.
1988 notch
erich306 is offline
post #3 of 12 Old 12-02-2007, 10:58 PM
Trader Feedback: (40)
Yup, same here, no problems with my QT kit aside from my powder coating developing a rash of some sort Lots of black spots in the silver coating on the cold side. Bernard is a stand up guy and told me to send the piping back and he will make sure it is redone right by the coater. I am just having too much fun with the car at the moment to pull the parts off
And, mine hits 10psi
'90 black notch 302 TFS TH kit TKO600 Mcleod scattershield 8.8 with Quicktime Turbo power!
Supernotch is offline
post #4 of 12 Old 12-03-2007, 01:17 AM
lethl-lx's Avatar
The kit has worked great No problems here !! Well with the kit that is . I`m waiting to get my new Tranny in. I seam to keep breaking them for some reason I`m also running just off the WG spring . Makes great Power !!!
91LX Vert 306 Winsor Sr. heads ,42lb inj , 70mm Accufab TB Typhoon intake ,TFS Stage 1 cam
70mm Turbo kit
lethl-lx is offline
post #5 of 12 Old 12-03-2007, 08:28 AM
BOOSTEDNOTCH's Avatar
No prolb hear. still running off the spring.. ONLY prolbem is TRACTION!!!!!!! Best $ spent by FAR>>>
BOOSTEDNOTCH is offline
post #6 of 12 Old 12-03-2007, 12:14 PM
No problems with kit, running on wg spring. Car will not hook until 4th gear.
05xterra is offline
post #7 of 12 Old 12-03-2007, 02:18 PM Thread Starter
how much boost do the wg springs run. i know it says 8 and 12, but does it actualy run that, or spike higher at times or anything?
post #8 of 12 Old 12-03-2007, 10:12 PM
The Tial box lists the spring at 8.9psi, but it runs @ 10 on my car. Confirmed with two different gauges.
Can't wait for my new engine combo and more boost
347 A4 block based with Eagle forged crank/rods and Diamond 8.5cr pistons, should be fun...
post #9 of 12 Old 12-06-2007, 10:59 AM
Tommyguns's Avatar
Does this kit come with the fp, fpr, inj. and maf? Thanx
Tommyguns is offline
post #10 of 12 Old 12-06-2007, 12:29 PM
ratedz's Avatar
No it does not - you supply tune and fuel.
1986 Mustang GT
525hp/626tq
ratedz is offline
post #11 of 12 Old 12-10-2007, 07:31 PM
Trader Feedback: (15)
What advice for a stock long block car to run this kit ?
intake upper lower
injectors
MAF sensor
TB
tune whats a SCT chip ?
Thanks Jim
90 7-UP is offline
post #12 of 12 Old 12-10-2007, 08:36 PM
ratedz's Avatar
Check the other thread - guys have posted all kinds of results in it.
1986 Mustang GT
525hp/626tq
ratedz is offline
