A few questions - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 11-27-2007, 11:41 PM Thread Starter
A few questions
Alright i got a few questions you guys might be able to help me out on. 1. I have the option to change from 373 to 308 rearend gears without spending any money via 93 cobra rearend in my garage would it be better for racing and driveability? 2. I have a f cam right now but my block is on its way out should i get a descent stocker and use o.e. cam or use the f cam and go through the degreeing it crap? Thanks Jon
wht89gt is offline
post #2 of 4 Old 11-27-2007, 11:53 PM
what tires do you run. is your car auto or stick and what mph rpm and gear are you trapping
jeffs89gt is offline
post #3 of 4 Old 11-28-2007, 12:01 AM Thread Starter
I run #### to (nitto) D/R not very sticky for my app. I trap 93mph going into 4th gear i was wondering if the extra load from 308 would work better for my combo?
wht89gt is offline
post #4 of 4 Old 11-28-2007, 11:15 PM
TurboJunky's Avatar
If you already know that the cam was ground correctly, do you really need to degree it again? You would have found this out when you initially degreed the cam. Why do it twice for a stock short block?
Jess
TurboJunky is offline
