how much power will it make? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 11-24-2007, 06:00 PM Thread Starter
Trader Feedback: (28)
1994 mustang 393w twin turbos (t4 60-1Hifi a/r .60 cold , a/r .68 hot ) steel crank, football rods arp bolts,forged speed pro pistons, 9.1compression,custom hyd roller cam motion turbo cam,1.6 roller rockers,super victor intake, cometic gaskets, pro topline heads 200cc 2.02 1.60 valves, proform 750 carb not sure on carb hat yet. c4trany, 3500 stall ,373 gears Let me know what you think? Chris
stang1986 is offline
post #2 of 10 Old 11-24-2007, 07:25 PM
a little, alot, there are too many variables. pumpgas? racegas? intercooled? planned boost level?
86 coupe, 408,glide 101mm
810rwhp pumpgas tune...........
90lx351 is offline
post #3 of 10 Old 11-24-2007, 08:01 PM Thread Starter
pumpgas,16psi , no intercooler chris
post #4 of 10 Old 12-03-2007, 01:34 PM Thread Starter
I would like to have 800fwhp. I would like to run low 10s in the 1/4 mile Thanks Chris
post #5 of 10 Old 12-03-2007, 04:16 PM
millhouse's Avatar
I'm not sure I'd risk running 16psi on a 9:1 setup without either intercooling or running meth injection. 8 psi, sure...12 would be pushing it. 16 however is asking for trouble, especially with head gasket's that won't blow out with detonation.
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #6 of 10 Old 12-03-2007, 04:27 PM
If set-up right it'll make more than enough to break them rods...
800rwp is alot to ask of the "stock football" rod. If your goign thru a c4 thats ruffly 840-50ish at the flywheel.
Though I've seen it done on a stock bottom end 351 without even bolt upgrade. Car was 2800lbs and ran 8.8's all day long...
02 F250 PSD superduty - The Mule no mods yet.
90 Hatch - Will never be done. best e.t. to date 10.30 @ 133 ;
86 Hatch - Made two track outings and was parted out best e.t. to date was 9.X @ 14X
igotaneed4speed is offline
post #7 of 10 Old 12-04-2007, 12:04 AM Thread Starter
I was looking 800fwh. would 10psi get me there? Thanks Chris
post #8 of 10 Old 12-04-2007, 07:25 AM
millhouse's Avatar
It would probably be close.
post #9 of 10 Old 12-19-2007, 11:51 AM Thread Starter
Iam going with a intercooler, dont want to hurt engine. Chris
post #10 of 10 Old 12-19-2007, 12:40 PM
Or if you are tracking the car you may be able to get away with race gas (110 or C16) and run that boost level; just a thought.
fastceli00 is offline
