y-pipe ??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 11-23-2007, 02:17 PM Thread Starter
y-pipe ???
hey everybody im puuting an exhaust setup on my car starting from my 3 1/2" downpipe. i need to see if anybody has a y-pipe for duals or if there's somewhere i can get one for a decent pric3e.
thanks
My90Stang is offline
post #2 of 10 Old 11-23-2007, 03:27 PM
Formerly known as 20thAniv
Unatural's Avatar
More than likely, you won't find a premade one. I made my own out of one 3" U bend and my old H pipe. It was pretty easy.
Wayne
'91 LX Hatch
Single turbo
, KWS Images on FB and IG
https://forums.corral.net/forums/turbochargers/1379238-unaturals-diy-build.html
Unatural is offline
post #3 of 10 Old 11-23-2007, 05:09 PM Thread Starter
right on, i have my old off-road h-pipe and flows still. i just have to do something with the end of the down pipe cause there is no flange on it.
post #4 of 10 Old 11-23-2007, 05:09 PM
Buddies
mfpmax is offline
post #5 of 10 Old 11-23-2007, 06:37 PM
NC STANG GUY's Avatar
Trader Feedback: (176)
Ponydown sells one but I'm not sure what size downpipe it hooks to.
http://ziptie007.phpwebhosting.com/c...roducts_id=243
I made my own for my B+G kit with 3.5" downpipe. Used a band clamp to hook the Y to the downpipe.
NC STANG GUY is offline
post #6 of 10 Old 11-23-2007, 06:51 PM
Unatural's Avatar
What I did was pick up a V band package (the clamp and both pieces to weld to the pipes) and used that. It makes it really easy to disconnect the pipe. Not sure if you're referring to your flows being the flow pipes that connect the h-pipe to the mufflers or actual flowmaster mufflers, but if you're talking about flowmaster mufflers, please get rid of them and get something better. There have been multiple "muffler" threads in here if you need some advise.
Wayne
'91 LX Hatch
Single turbo
Unatural is offline
post #7 of 10 Old 11-24-2007, 12:12 AM Thread Starter
right on guys. i appreciate all the advice. i was referring to have flowmasters and im deffinetly not putting them back on my car. me and buddy were going to cut them open and run a pipe straight through them but i have offset inlets and outlets so im going to just get some glasspacks i think. the v-clamp setup sounds good cause when you i get to the track that #### will come off.
post #8 of 10 Old 11-24-2007, 08:06 PM
Adrenalin's Avatar
This is for HPs 94-95 turbo kit.
http://www.turbochargedpower.com/94-...Side%20Kit.htm
As for price, I'm not sure how much they would charge just for that piece.
348ci, 4R75W, 95, Turbo, Fobra project. Check out my build in the Member Build-Up Projects.
Adrenalin is offline
post #9 of 10 Old 11-25-2007, 12:11 AM
/\/otchback92's Avatar
Here's the one I made for my car.
/\/otchback92 is offline
post #10 of 10 Old 11-26-2007, 12:27 PM
Trader Feedback: (36)
Flowmaster makes a Y-pipe...if you don't mind spending the $$ 45.00 or so. 3" to dual 2-1/2"
scotng is offline
