Any advice on installing a 2-step on a 5 speed? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 11-04-2007, 06:04 PM Thread Starter
Thunder5.0's Avatar
Question Any advice on installing a 2-step on a 5 speed?
What is the best way to hook up a 2 step rev limiter with a 5 speed?
Thunder5.0 is offline
post #2 of 13 Old 11-05-2007, 06:06 PM
red89coupe's Avatar
Trader Feedback: (31)
however the instructions say??
red89coupe is offline
post #3 of 13 Old 11-05-2007, 06:13 PM
red89coupe's Avatar
not sure exactly what your asking but.. I run a MSD digital 6 plus and it has the 2 step built in. I use my winshield washer button to turn it on lol just hold it in and release when ready lol.. Herd of people putting on th C/C buttons on the steering wheel too
post #4 of 13 Old 11-05-2007, 10:05 PM Thread Starter
Thunder5.0's Avatar
I have the digital 6 too. So you time the button as you release the clutch?
Anyone hook up a switch beneath the clutch pedal?
post #5 of 13 Old 11-05-2007, 10:21 PM
red89coupe's Avatar
Yes
yeah I tried it the only problem is when I shifted the 2 step came on but I do have mine set pretty low (3500rpm). It came on between every shift and sounded like crap!!!
post #6 of 13 Old 11-05-2007, 10:48 PM
C MY 4D's Avatar
Originally Posted by red89coupe View Post
Yes
No actually you can do it with a relay so that it only activates when the clutch is pushed in after hitting a momentary button.... here is a diagram with a nitrous kit wired in.
Poor Boy Racing
C MY 4D is offline
post #7 of 13 Old 11-07-2007, 04:36 PM
Trader Feedback: (28)
I had mine on the Hurst line lock shifter ball..
Jeremy
1992 Mustang GT, F150 Coyote swap, Mustang intake cams, 2018 Intake, JLT Cold Air, Fidanza V2 Clutch, G101a H-pattern, 2900lbs (work in progress)--10.60 @126 mph
1972 Maverick Sprint
87Saleen209 is offline
post #8 of 13 Old 11-07-2007, 09:34 PM
Trader Feedback: (40)
How do you install a momentary switch under the clutch pedal???
'90 black notch 302 TFS TH kit TKO600 Mcleod scattershield 8.8 with Quicktime Turbo power!
Supernotch is offline
post #9 of 13 Old 11-07-2007, 09:41 PM
C MY 4D's Avatar
you don't; you tie into the clutch switch..... install the momentary switch anywhere..... what this setup will do is when you come up to the line after the burnout you press and hold the momentary switch, depress clutch, let off of the momentary switch. 2 step is activated.
As soon as you press the momentary switch. it then transfers power to the clutch switch. the clutch switch will keep the 2 step on until you let off of the clutch. the 2 step will not come back on until you arm it with the momentary switch again.
Poor Boy Racing
C MY 4D is offline
post #10 of 13 Old 11-07-2007, 10:56 PM
red89coupe's Avatar
thats NICE.. very good idea !! I see MSD even sells the Double poleDouble throw relays. They are only $32 I think I will have to get one.. The BIG problem FOR ME will be hooking it up... Man I suck at ele relays/wiring ect.. HOPE I can figure it out!!! lol lol
post #11 of 13 Old 11-07-2007, 11:04 PM
C MY 4D's Avatar
I only show a DPDT relay because I was also using it for nitrous. you can use a standard 5 prong relay.
When this was going in my car what I would do is.....
Pull up to line, push momentary switch, depress clutch, release momentary switch, arm nitrous, hold gas to the floor. When I released the clutch the two step would turn off and the nitrous would turn on.
Poor Boy Racing
C MY 4D is offline
post #12 of 13 Old 11-08-2007, 12:59 AM
Very cool Which wire on the clutch switch is used? '90 Fox
post #13 of 13 Old 11-08-2007, 10:59 PM
C MY 4D's Avatar
Theoretically it should have a 12v input and a 12v output. You need to splice into the output for it. Should be easy to find with a test light but I would check the voltage just to make sure it is 12v.
Poor Boy Racing
C MY 4D is offline
