help with turbo set up - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 10-28-2007, 07:47 PM Thread Starter
1madracer's Avatar
Trader Feedback: (15)
Im going the turbo route so Im sending my motor off to the machine shop to put lower compression pistons in it .. I need some questions answered that I didnt find the answers to thru a search... Is Bg the best price for turbo manifolds out there???? Im going to use 60lb injectors , and doing custom tune on the sct so do I need (and where if i do) to have my maf sent out and calibrated for the 60s and set up so I can use it as a blothru??? The reason Im not buying a kit is because Ive already gat a garret T04z ball bearing turbo, intercooler , wastgate , bov ect. I want to run around 15lbs of boost...
95 Cobra SVT, 351W
90 Gt, 308,-SOLD-
1madracer is offline
post #2 of 6 Old 10-28-2007, 09:00 PM
Erich's Avatar
B and G makes nice turbo manifolds for a fair price. Cheapest is not best. If you are doing an SCT tune on a chip, you don't need to get your maf recalibrated first-unless you need to driver the car. Blow thru or draw thru works fine.
Erich
Erich is offline
post #3 of 6 Old 10-30-2007, 11:47 AM Thread Starter
1madracer's Avatar
Im not tryin to get the cheapest but Im not tryin to spend 900 either.. Can any think of anything else i need???
95 Cobra SVT, 351W
90 Gt, 308,-SOLD-
post #4 of 6 Old 10-31-2007, 07:02 AM
Erich's Avatar
Do you have cold side tubing, silicone connectors, band clampss, Oil lines, preferably ARP head studs, 3.27 gears, heat wrap, possibly upgraded ignition. You may have this stuff already but I'm just throwin it out there. Go with the B and G, they make good stuff for reasonable prices and it seems to fit nicely.
Erich
Erich is offline
post #5 of 6 Old 10-31-2007, 11:12 AM Thread Starter
1madracer's Avatar
Ive got 373 in it now .. Is that the gear I should run ??? Ive got all the u bends at the shop to make the piping
95 Cobra SVT, 351W
90 Gt, 308,-SOLD-
post #6 of 6 Old 10-31-2007, 11:15 AM
Zacharyx's Avatar
I would look into the MAF exteneder or the MAFIA
636rwhp/576rwtq or 852/900 RSAE corrected
"And the dynos rumbled, and God spoke 'Take thine turbos, install them upon thine car, and destroy the many ricers!'
Zacharyx is offline
