Tuning..How do you guys have yours?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 25 Old 10-26-2007, 02:38 PM Thread Starter
93Svt331's Avatar
Trader Feedback: (38)
I have complete the install of my turbo kit and now looking at different ways of tuning it. Car has 255 intank and t-rex inline..and need to get 60s or 42s
please list what you are using to tune your car
thanks guys
90 lx, 408w, T56, 88mm
93Svt331 is offline
post #2 of 25 Old 10-26-2007, 02:45 PM
What are your mods and expected horse power levels?
r.barn is offline
post #3 of 25 Old 10-26-2007, 06:50 PM
Trader Feedback: (40)
Get the 60's for sure. My car with QT kit and a TFS/Holley top end hit 504/500 with the 42's and a SCT tune. The injectors are getting close to maxing out at this level. I wish I gotten the 60's now
'90 black notch 302 TFS TH kit TKO600 Mcleod scattershield 8.8 with Quicktime Turbo power!
Supernotch is offline
post #4 of 25 Old 10-26-2007, 07:15 PM Thread Starter
93Svt331's Avatar
looking for 550
93Svt331 is offline
post #5 of 25 Old 10-26-2007, 07:16 PM Thread Starter
93Svt331's Avatar
is there a calibrated m/a for 60s that isnt sct??
93Svt331 is offline
post #6 of 25 Old 10-26-2007, 07:49 PM
Blackfive0's Avatar
Trader Feedback: (62)
I am using a SCT meter and chip, IF you are looking to get around 550 then I would go with the 60's. I had Bod Kurgan tune mine, I would check it out.
http://www.kurganmotorsports.com/
Blackfive0 is offline
post #7 of 25 Old 10-26-2007, 08:19 PM
Originally Posted by 93Svt331 View Post
looking for 550
60's
r.barn is offline
post #8 of 25 Old 10-27-2007, 12:59 AM
Zacharyx's Avatar
You will be much happier if you go ahead and do the 60s. Figure we never have enough HP so why buy the 42s and decide you need more later. And I don't think the SCT meters are calibrated they should be done through the ECU like the stock meter. If your cold side is 3" or smaller you may be able to get away with your stock MAF and the EXtender or a Mafia
636rwhp/576rwtq or 852/900 RSAE corrected
"And the dynos rumbled, and God spoke 'Take thine turbos, install them upon thine car, and destroy the many ricers!'
Zacharyx is offline
post #9 of 25 Old 10-27-2007, 11:26 AM
billyNOTnice's Avatar
Trader Feedback: (80)
i'm running 42# on mine and it's fine, now my buddy is running 42# on his and he's running out of fuel. I'd probably go with the 60# since they are basically the same drivability.
----------Dart 363 Turbo 93 Cobra #3193----------
--------------Magnum T56--------------
billyNOTnice is offline
post #10 of 25 Old 10-27-2007, 01:17 PM Thread Starter
93Svt331's Avatar
yeah ill be going with the 60s..Ive been watching your setup on svtper..sweet ride man..
93Svt331 is offline
post #11 of 25 Old 10-27-2007, 01:19 PM Thread Starter
93Svt331's Avatar
are you on one tune or multiple tunes?
93Svt331 is offline
post #12 of 25 Old 10-27-2007, 01:42 PM
tuffyman's Avatar
Anderson PMs with injector driver, 84 lb Precision Turbo injectors, SCT BA3000 meter, Aeromotive Eliminator fuel system.
tuffyman is offline
post #13 of 25 Old 10-28-2007, 11:48 AM
Blackfive0's Avatar
I am running two tunes. One for low boost and one for higher boost. With the tune I that I have gotten I have taken the car for a trips up and down the high with a best of about 24mpg.
post #14 of 25 Old 10-29-2007, 06:53 PM Thread Starter
93Svt331's Avatar
are the tunes on chips or a sct switch?
93Svt331 is offline
post #15 of 25 Old 10-29-2007, 07:07 PM
xr8240's Avatar
65's with two 044 Bosch pumps with Walbro 255 intank feeding surge tank...
Fuel pressure at idle is 40Lb, wasted spark..
Stand alone haltech E11v2....
xr8240 is offline
post #16 of 25 Old 10-29-2007, 08:27 PM
Trader Feedback: (28)
Stock untuned A9L, 76mm C&L MAF, 42lb injectors, A1000 pump and Aeromotive regulator. No dyno numbers, but running at 11.4:1 A/F Ratio and a 9.81 @ 139 mph quarter mile.
Jeremy
1992 Mustang GT, F150 Coyote swap, Mustang intake cams, 2018 Intake, JLT Cold Air, Fidanza V2 Clutch, G101a H-pattern, 2900lbs (work in progress)--10.60 @126 mph
1972 Maverick Sprint
87Saleen209 is offline
post #17 of 25 Old 10-29-2007, 09:50 PM
red89coupe's Avatar
Trader Feedback: (31)
Thats nuttz !! I like it !! some sick numbers!!
I run stock untuned A9P (auto comp) 3in PMAS pro tube (blow threw). 42s feed by a 255lph high pressure intank.
red89coupe is offline
post #18 of 25 Old 10-29-2007, 09:51 PM
FastCat70's Avatar
SCT Chip and BA2800 MAF with a
SPEEDYDYNO tune.
10.90 in a 3660lb car with a AOD and A/C
FastCat70 is offline
post #19 of 25 Old 10-29-2007, 10:04 PM
Blackfive0's Avatar
The tunes are on the Chip and I have a little switch I flip to change from one to another.
post #20 of 25 Old 10-30-2007, 06:30 PM
60s , aftermarket MAF , and good tune with a chip .....
93GRNLXNVA is offline
post #21 of 25 Old 10-30-2007, 06:32 PM
just so people know , this is not the NORM ......very few guys are able to run sets ups like this , where is your base timing at ? and how much boost are you seeing ?
post #22 of 25 Old 10-30-2007, 07:00 PM Thread Starter
93Svt331's Avatar
thats crazy
93Svt331 is offline
post #23 of 25 Old 10-31-2007, 08:36 AM
You're right, it's not the norm. I've just kept a really good eye on my wideband and have been running a mix of race gas (probably 104 octane with a 91 pump/110 race mix). My timing is locked at 25* Adv and my boost is around 18-20 psi. I'm sure the 42's are going static and my MAF is pegging according to the LM-1 w/ RPM kit. The best thing of all is, it's very streetable. I have little to no surge, idles at 14.7 air/fuel ratio and cruises at 14.7 air/fuel so it pretty much runs like a stocker and can be driven anywhere you want to buy gas for. It will daily drive on 91 octane with the boost cranked down.
This winter it will probably get some nice upgrades.
Jeremy
post #24 of 25 Old 11-01-2007, 08:53 AM
trbofox's Avatar
ABNORMAL here also. Stock A9L spout locked out @20 degrees 42lb. injectors been doing this for four yaers and 25K miles. These numbers were with GT40 heads and a Cobra intake I had laying around from my 93Cobra,I'm sure that with the Trick-Flow lower and Hogan upper I can do better than that, need to go to dyno.
trbofox is offline
post #25 of 25 Old 11-01-2007, 09:11 AM
I've been meaning to tell you that I dig your car. It was a very nice photo shoot in the mag.
Jeremy
