How well do the T3/T4 twin set ups work? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 10-21-2007, 08:28 PM Thread Starter
NosDog3's Avatar
A little background...
I have a Sportsman 342 on nitrous right now, the engine is making about 425 on its own and it has 8.5/1CR. I bought/built the engine around a T trim and had to sell that last year to finish the car up. I bought the nitrous kit just to make due...
Now Im looking for a winter upgrade and thinking about these kits...anyone have any experience with them? Or should I just save my money and get a bigger kit right off the bat? I was wondering how much boost they are good for and how much of a HP gain I should expect after proper tuning. Thanks in advance
Pat
88GT in the 10s
08 Buell 1125R (wifes toy)
Street Lethal Performance (724) 944-2814
NosDog3 is offline
post #2 of 7 Old 10-22-2007, 07:03 AM
xr8240's Avatar
I have twin SC61's Dual ball bearing, water cooled, 76 trim, .63 A.R... With 646 rwhp / 482 rwkw...
On a 330 etc...
xr8240 is offline
post #3 of 7 Old 10-22-2007, 03:25 PM
Well there are numerous variants of the T3/T4 hybrids...you can make anywhere up to 1000HP depending on the turbos. The HP Twin Turbo 99-04 kits is one example. They run 50-67 Trim T3/T4 hybrids make anywhere from 450-900HP.
mfpmax is offline
post #4 of 7 Old 10-22-2007, 04:20 PM Thread Starter
NosDog3's Avatar
here is the kit I was considering, with a possible upgrade in the future (to bigger/better turbos). I figure even if the turbos are non rebuildable and inexpensive, I would still have the remainder of the kit in place for the upgrade. This is just one of them, but there are many like it on ebay...
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=013
Any thoughts?
88GT in the 10s
NosDog3 is offline
post #5 of 7 Old 10-27-2007, 01:41 PM
you get what you pay for... turbos will probably go bad withn 1000 miles... but the piping is there...
JBR87 is offline
post #6 of 7 Old 11-04-2007, 12:00 PM
My buddy bought that very kit. It doesn't look too bad of quality and really can speak for the turbos because we don't have the kit on yet the thing I don't like about it is how the intercooler mounts. It mounts as it lays in the one picture where it was on the ground and it sits right to the back of the core support under the drive belt other than that the kit doesn't look too bad
Strub1975 is offline
post #7 of 7 Old 11-06-2007, 02:22 AM
if you are weak on weld/fab dont pick this up. ive done this kit and the downpipes are a m f. the intercooler looks killer in place with an air intake continuous across from right to left. the headers put the turbos on bad areas that need to be raised.shift the ac also. but.....garrett does have housing options and internally gated compressors that will mate to the pipes that you make. ill try to pm pics but email me at [email protected]
forst1 is offline
