twin turbo install questions!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 10-14-2007, 11:47 PM Thread Starter
well i am putting my built 9:1 306 with aluminum heads and sage 2 cam and edelbrock intake. (just listing major supporting mods) into my 1998 cobra
i am installing 2 garret gt28 turbos' (internally gated) and i have a couple questions before mocking it up
1. if the kit was made for a fox will the only think i need to change is the inlet pipe from ic to tb?
2. where do i tap for oil feed and return lines?
3. i know how to run a boost controller from nipple in charge piping on the outlet of the turbo to the wastegate, but how do i run a MBC with the twins to have the same boost on each turbo.
4. Where do i run a boost gauge from
5. what kind of boost should i run and power to expect. i will have n20 hooked up into the charge pipe. small shot to just cool the charge.
6. i have 42lb injectors with pro m mass air meter, and should i just mount that in my intake pipe to compensate for injectors and is that all i really need on a tune to drive it and boost. not necessarily perform at 100% capablity or acess all of its power. but can it run be drove hard how that is.
7. where do i tap for coolant feed/return
i really appreciate it and i plan to add and remove questions as answered and if some other things come up
DragSN95 is offline
post #2 of 4 Old 10-14-2007, 11:55 PM Thread Starter
60 A/R EXHAUST
.63 COMPRESSOR
DUAL BALL BEARINGS
---turbo info
DragSN95 is offline
post #3 of 4 Old 10-15-2007, 08:11 AM
millhouse's Avatar
Does it hook into the stock H-Pipe location? If so, it was my understanding that the sn95 and fox setups were different due to header differences. There is no guarantee that the rest of the cold side will fit…and unless you have no qualms doing some fab work, I would ask the question from whoever made the kit personally.
You'll need to come off of the oil pressure log on the front-drivers side of the engine. You can either add some inline T fittings or tap the log itself. I've done both, and tapping the log looks both cleaner…and has far less issues sealing.
As far as the returns go, you'll need to either drill the pan in the appropriate locations and weld a bung in…or go with the punch/tap method used by Vortec. Both work great…however, the drill and tap method is a bit more tedious as you need to ensure no shavings enter the oil pan. As far as the locations go, I don't have them at my disposal, but some searching either here over turbomustangs.com for should yield excellent results.
For the boost controller you'll run a vacuum line from either the upper intake or vacuum tree on the firewall to the MBC….after which you will split it off and run it to both wastegate actuators.
Hook it up to the vacuum tree on the firewall.
What h/c/i are you running? If you are running the stock longblock, you should be able to go up to 12psi as long as your tune is on. I think your underestimating the effectiveness of a turbo setup though…as you will not need the n20 to cool jack. You should have no issues running block splitting h/p levels with 12psi and a safe tune. The n20 is simply not necessary…and really not worth the extra expense/risk.
Now, if you have an aftermarket h/c/I setup…you'll be able to run less boost and achieve the same h/p levels. From what I've seen, ~8psi should get you there with a good h/c/I setup.
Well, yes…and no really. It seems that the sn95 computer setups are a bit more dangerous to simply leave it all to the sensor itself. What you'll typically see for us foxbody guys who choose to go the cheap route is…well run the mass air calibrated to the injectors, set the base timing to 18*-20* and leave the spout out. This locks the timing and ensures that the computer can’t compensate. For WOT performance it's really not a bad way to go, and you wont be leaving to awful much on the table. It will however hurt daily drivability somewhat. This can be seen on cold starts and low load acceleration where it may feel a bit doggy.
A good spot seems to be the heater rail that's connected to the lower intake.
Before you get to far into this, I highly suggest doing some searching and looking at what others have done over on turbomustans.com. Many over there have documented their builds and have all the info and more.
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #4 of 4 Old 10-15-2007, 10:51 AM Thread Starter
thanks very much i appreciate it!
i have performer rpm aluminum heads, performer rpm inakte and cam.
im familiar with turbo setups as coming from a 4cyl point of view.
i wll lerk turbo mustangs and hopefully find something a good build thread!
DragSN95 is offline
