New Turbo Build Up - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 10-12-2007, 11:52 PM Thread Starter
New Turbo Build Up
Hello all,
New to the turbo crowd and reading/learning everyday. I finally after owning several blown Stangs, including a stroked / Novi blown 01 Cobra that made 700rwhp bit the bullet and am going all out turbo on my 06 GT. What do you all think about this buildup and how much power should I expect?
06 Mustang GT
300" Stroker Motor
Ported heads with oversized valves
60# Injectors / GT500 Fuel Pump Setup
MMR Stage II Turbo grind cams
HP single 76mm intercooled kit
Planning on 20#s for the street and 25#s for the track
Any suggestions? I am going with a 3.55 gear also, should that give enough load to build the boost?
06 Black Mustang GT
Eleanor Package
S-Trim W/Meth Injection 503RWHP
JBA Long Tube Headers / 4.10's
SlwGT is offline
post #2 of 3 Old 10-13-2007, 12:11 AM
I am by no means a fuel injection expert, but are 60lb injectors going to support enough fuel for 25lbs of boost with that setup?
1quick6 is offline
post #3 of 3 Old 10-16-2007, 12:43 PM
I'd go with 60lbs also. You could get away with 55lbs but wouldn't have any run to grow.
arnold22 is offline
