stock manafolds for turbo? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 10-07-2007, 05:22 PM Thread Starter
Im new to this side boost im going from a blower to a turbo and were doing a diy kit. wondering if the stock hearers are going to be ok to use (96 cobra) or do you have to get ones made? not trying to be real cheap but at least pratical. thanks
moneypit cobra is offline
post #2 of 5 Old 10-09-2007, 01:50 AM
you can use the stock manifolds but you cannot turn them around, you have to run them back and then run your pipes forward. hellion uses the stock manifolds and there 03-04 cobra kit puts down 800 plus horses at the wheels.
fearsjohn is offline
post #3 of 5 Old 10-09-2007, 09:48 PM Thread Starter
wondering why you cant turn them around with a oil filter relocation kit? or is there other reasons
post #4 of 5 Old 10-12-2007, 06:35 PM
Please note that the stock manifolds on an 03, are a bit different then what is on your 96. The only way I see being able to flip the stock pieces, would be to delete a/c, swaybar, possibly power steering, as well as oil cooler and relocation of p/s lines and wiring on drivers side.
BTW, I fabricate custom turbo headers ( 4-1 tubular design) for your application.
www.turbochargedinnovation.com
-Mike
poostang is offline
post #5 of 5 Old 10-15-2007, 08:49 AM
You have to delete ac and run a remote oil plate, thats it. ps stays.
You might want to get that Honda sprayed, it sounds like it has a swarm of pissed off bees in your folgers can.
mustangpwr98 is offline
