Should I get this 60/63 garrett T3??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 10-02-2007, 07:09 AM Thread Starter
Erich's Avatar
I found this garrett 60/63 for pretty cheap-about 40 bucks. It is missing the wastegate housing, the bolts for that are broken off in the turbo (or at least most of them) and there is a crack by the wastegate hole. There is some side to side play of the impeller but in and out is fine. There is no contact between the the housings and blades when you spin it. I was thinking about getting this unit as the beginning of a second generation setup for my car. Obviously I would rebuild it but are those broken bolts and crack enought to stay away?? No pics sorry.
Erich
Erich is offline
post #2 of 5 Old 10-02-2007, 10:35 AM
fred50stang's Avatar
Sure, $40 isnt bad at all. Add to your parts also.
fred50stang is offline
post #3 of 5 Old 10-06-2007, 03:01 PM
Scones's Avatar
they all have cracks around the wastegate actuator hole...next to impossible to find one that doesn't...you're just looking to see how many and how big they are lol. the broken bolts is also a common issue and most machine shops can get them out for you easy enough, and probably weld up the cracks in the housing for a few dollars. also, any rebuild place like evergreen turbo do that for you if you want to have it rebuilt instead of doing it yourself. for $40 i'd grab and keep it around as a spare lol
1986 5.0TT Tribute Car
2010 Ranger 4.0
1989 Kawasaki Ninja ZX6
Scones is offline
post #4 of 5 Old 10-07-2007, 08:42 AM Thread Starter
Erich's Avatar
Maybe I will swing by there today and see if it is still there.
Erich
Erich is offline
post #5 of 5 Old 10-13-2007, 12:24 PM
brian15's Avatar
Erich
id get it , ive started a collection of my own , i have 2 .60 / .48's , one 60.63 and some funky .50/.63
brian15 is offline
