what combo for $6K - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 10-01-2007, 01:46 PM Thread Starter
what combo for $6K
I have 6K or so.
I will have a forged 331 Dart block w/ TW heads that flow about 300/210.
I have a GT-40 upper and lower that I am just thinking about porting.
What turbo kit and supporting mods would I need to buy that I could do myself along with the help of a friend who is a prof wrench?
I will be putting this power to the ground through an auto and prob 3.27 gears.
90' Mustang Coupe is the car.
I want to have 450 rwhp and 550tq for everyday driving, but the potential for 600rwhp.
I'm thinking a 66mm turbo kit would do, but what will I need for everything?
Thanks in advance.
1996 Cobra. Laser Red. 4.10's. BBK LT's & H along with MagnaFlows, JLT CAI and Steeda underdrives. 273/272 SAE w/ 91 CA octane. (Father's car now)
2003 Mach 1. White. 4.30's, MRT O/R H, SLP LM2, JLT CAI, PHP intake spacer, XCal2. 286/315
Caleb_Cook is offline
post #2 of 12 Old 10-01-2007, 02:10 PM
rob
rob's Avatar
Trader Feedback: (23)
quicktime turbo with 76mm turbo upgrade, 60lb injectors, meter and a tune.
rob is offline
post #3 of 12 Old 10-01-2007, 06:01 PM
1foxbody32's Avatar
Trader Feedback: (26)
x2
SIRACING.NET
1foxbody32 is offline
post #4 of 12 Old 10-01-2007, 06:43 PM
I'd definately get rid of that GT40 intake. Ported or not...
306, TFS heads, Victor EFI, XE282, Tremec, 10" tires, and NX nozzle
99GTC is offline
post #5 of 12 Old 10-02-2007, 08:06 AM
rob
rob's Avatar
why?
rob is offline
post #6 of 12 Old 10-02-2007, 10:33 AM
fred50stang's Avatar
HPerformance sells a really nice kit. You can make the numbers you want with the stage 1 kit, which is a 60mm turbo. It's all jet-hot coated and mechanic friendly.
The GT-40 intake is essentially 'done' at about 5-5500 rpm if not sooner. You will make huge torque down low though. You could port the lower and put a box upper and that will help get a little more rpm for the t/w's to start working.
x3- With a good meter and 60# inj.
fred50stang is offline
post #7 of 12 Old 10-02-2007, 11:59 AM Thread Starter
I was told to get a PT6676 Precision turbo upgrade on the base quicktime turbo kit.
A forged 4 bolt shortblock. TW heads, and Trick Flow intake. 2600 SCT ba MAF, 75mm tb, 42 or 60lb injectors depending on much power I want ( 450rwhp everyday tune, 575 rwhp max safe tune, so probably 60's )
I am concerned with the TCI Streetfighter Transmission. Should I pull it/sell it, and then get a Art Carr Street Terminator piece? 2600 stall be enough?
I will also get a LM-1 wide band and A/F guage for the column prob.
I had a question about the tune though? What piggy back system works good with the EEC-IV's? With the late model ECM's tuning is easy, but I have no experience with the older ECM's.
AEM, Tweecer? What provides the best tune?
Should I go electronic boost controller or just keep it to a spring and simple?
Thanks again.
post #8 of 12 Old 10-02-2007, 01:46 PM
why?
It will become a bottle neck. You are trying to force air through a turbo to some big heads but inbetween you have a little intake. That will become a big restriction and cause the power to drop off fast.
99GTC is offline
post #9 of 12 Old 10-02-2007, 01:53 PM
Most will tell you to go with a Dart, MOW, or BOSS block. If you can afford it, DO IT! If you can't get ahold of a Mexican block or a Pre 75 block. A track heat intake would do alright. I wouldn't mess with the 2600, I got the 3000 and it drives amazing at my low power level and I won't max it out until 800ish rwhp. 60lb injectors, 42lbs max out around 550rwhp.
Thanks again.
Take the car somewhere and have a tuner dyno tune the car. You could do a flip switch. The low boost setting on one tune and turn a nob and your other tune for higher boost would be there.
If I were you I would go with an electric boost controler. Mount your chip switch somewhere close so while you are driving you can turn onto the higher boost setting then dial in that boost on the EBC and BAM there you go. 100-200rwhp more on the fly. You would have people wondering if you just sprayed nitrous!
99GTC is offline
post #10 of 12 Old 10-09-2007, 06:51 PM
My car with the base Quicktime kit is putting down 444/480 hp/tq on 8lbs with a stock short block/gt-40 irons/cobra intake. Your motor should make way more than my setup.
05xterra is offline
post #11 of 12 Old 10-10-2007, 01:32 AM
mind sharing with them what it made before the turbo kit
Newt-Rod is offline
post #12 of 12 Old 10-10-2007, 11:31 AM
It made 215/255 hp/tq before the turbo, I would recomend the Quicktime kit to anyone who wants a turbo kit for a mustang.
05xterra is offline
