T6 or T4 Need Help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 09-22-2007, 11:41 PM Thread Starter
Trader Feedback: (28)
T6 or T4 Need Help
I have a Garrett TV80102 New rebuilt, compress housing A/R 81, compress wheel 86mm , exhaust housing T6 A/R 1.39 . Ok what I would like to know is there a T4 turbo that would just as good on a 393ci engine with out alot of back press, so I can git headers and cross over pipe . With out paying alot of $$$$$$$$$$$$$ Thanks Chris
stang1986 is offline
post #2 of 8 Old 09-25-2007, 01:52 PM
I wouldn't run a T4 based turbo on a 393. It will be a choke point. You could run one, but you'll be facing backpressure issues that will limit how much boost you'll be able to get out of the turbo.
Ben in Houston is offline
post #3 of 8 Old 09-26-2007, 05:06 PM
96mustang460cid's Avatar
I agree with Ben (from Houston) that a single T4 is too small for a 393. Depending on your goals, though, I question how easily you'll spool the TV8102. I actually have one of those turbos and am putting it on a 460.
If you're car car will spend more time on the street, I'd seriously consider a twin setup. I think you'd have better spool characteristics, similar power levels, and easier packaging.
Have a good day!
Michael
2003 Ford F150 Supercrew--------1996 Ford Mustang
Stroked BBF------------------------2.3t
Garrett 98mm turbocharger------12.10 @ 114 mph
96mustang460cid is offline
post #4 of 8 Old 09-26-2007, 08:04 PM
xr8240's Avatar
How about an S400 ??? Or S475 ???
From Mike at Majestic ?? [email protected]
xr8240 is offline
post #5 of 8 Old 09-26-2007, 08:31 PM
If you're talking with Majestic about turbos, I'd imagine they more qualified than any of us to answer that question.
On a side note, though, if you decide not to use the TV8102, PM me if you'd like to sell it. I have a BBF friend who's looking for one.
Have a good day!
Michael
Edit: I just realized the above quote wasn't from the OP. Disregard my comment.
post #6 of 8 Old 09-27-2007, 12:30 PM
I don't normally like making blanket statements, but around 1000hp is where I'd like to move to a T6 on a single turbo. We've done a lot more than that on T4, and had cars with less than that on T6, but it's a decent break point. I wouldn't want to run a T4 housing on a turbo that size.
Mark Conte is offline
post #7 of 8 Old 09-27-2007, 05:29 PM
xr8240's Avatar
I agree .. You also need to consider its for 400 ci engine....
They fit these to 2.5 Totota's [1JZGTE] make over 800 rwhp on 30 lb boost...80mm , 1.01 A.R...
Depends on engine build? It would need to be strong enough ....
Garrett TV80102 would be comparable for SINGLE turbo...
xr8240 is offline
post #8 of 8 Old 09-30-2007, 10:16 PM Thread Starter
t4 or t6
All Iam looking to get is 800hp to the the tires if I can Get it out you a t4 turbo that is great. Chris
