dose this make sense - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 09-21-2007, 10:12 AM Thread Starter
well i just got back from the shop were my car is and they just informed me that they upped the boost from 10 to 14 and didnt see any increase in whp. they said that i have several oil leaks, ( just put the kit on the car) the one guy there was saying that maybe the motor needs rebuilt and that its blowing oil out and loosing the other 4 lbs of boost that they added, thus making the same power at 14 as it did at 10. Dose tat make sense or what i am hoping that the oil leaks are some minor #### like the oil return on dip stick tube
thanks
scotty230 is offline
post #2 of 3 Old 09-21-2007, 04:20 PM
since boost is a measure of resistance to flow, if you your setup is very restrictive, the higher pressure may demonstrate that the engine is incapable of ingesting a larger volume of air.
the efficiency of your compressor is also important, if you are pushing air efficiently at 10 psi, and inefficiently at 14 psi, the air temp will be greater at 14 psi and therefore the air density will be lower, which could be resulting in a comparable mass of air entering the combustion chamber despite the higher pressure.
even if the compressor efficiency is comparable at 10 and 14 psi, the larger volume of air moving through the piping/intake/etc will itself generate more heat thereby reducing it's own air density, possibly resulting in the consumption of no more air mass despite the increase in pressure.
it is also possible that the engine is extremely tired and in need of a rebuild and that it's combustion chambers are unable to contain the additional mass of air that might be forced in at 14 psi compared to 10 psi. this would result in excessive crank-case pressurization, which in turn could blow oil out of various openings.
In short, any of the above factors, any combination of the above factors, and any number of other possible explanations make it perfectly feasible that you would indeed see no increase in power despite the increase in boost pressure.
Pope is offline
post #3 of 3 Old 09-21-2007, 05:26 PM Thread Starter
thanks alot pope, i think tthat the motor might be tired lol i noticed that its blowin oil out several spots now, but then again it never did that before i put the turbo kit on the car. i think i miht just say the hell with it and be happy with it set at 10lbs and start building a new motor,
