anyone put a hellion kit on a non ac fox - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 09-19-2007, 09:00 AM Thread Starter
if so could you post pics and did you have to buy a smaller water pump pullie?also if you have no smog pump do you have to buy a smog pump eliminator
ahurl90 is offline
post #2 of 7 Old 09-19-2007, 10:45 AM
rob
rob's Avatar
Trader Feedback: (23)
hellion uses the vortech brackets. you will need to use a smog pump emiminator. i recommend the upr because it has the correct hole on the side for a superharger.
i think your going to have to put your ps back in stock location and run a ac eliminator pulley. upr also sells it.
rob is offline
post #3 of 7 Old 09-21-2007, 09:56 AM
brian15's Avatar
i ran my hellion with no a/c p/s or smog delete : )
brian15 is offline
post #4 of 7 Old 09-21-2007, 12:22 PM
silver89coupe's Avatar
do you have any pictures (how the belt is run)
silver89coupe is offline
post #5 of 7 Old 09-22-2007, 01:23 AM
Trader Feedback: (22)
turboLXstang is offline
post #6 of 7 Old 09-22-2007, 01:26 AM
You'll need the UPR Smog and A/C Delete Kits, lose your underdrive pullyes, your making enough heat as it is, good luck.
post #7 of 7 Old 09-23-2007, 10:44 AM
the way this quote sounds(he did it without the delete kits)
maybe i am reading it wrong
