use a draw thru as a blow thru - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 09-14-2007, 02:43 PM Thread Starter
is there anyway to do this? I dont mind spending the money but if i can spend it else where ie 31 spline axels id much rather. Thanks bros
boss block, tko, turbo, lots of go
95cobra50 is offline
post #2 of 3 Old 09-16-2007, 09:46 PM
red89coupe's Avatar
Trader Feedback: (31)
what brand MAF is it?? you might be able to get it recalibrated for what ever you need. if you do decide to get a new meter I strongly suggest the PMAS pro tube.
red89coupe is offline
post #3 of 3 Old 09-17-2007, 07:52 AM
Erich's Avatar
No problem with doing that. If you are going to get it dynotuned, a lightning maf can be adapted. They are about 80 bucks from diversified (cheap cheap said the bird). But you HAVE to get it tuned to run. You would need to make an adapter from the airfilter end to tubing. Procharged makes an adapter like that for their blower kits.
Erich
Erich is offline
