t70 guys inside - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 09-06-2007, 05:33 PM Thread Starter
t70 guys inside
which ar did you go with?im looking at either a .68 .70 or .96. What is going to be the difference in the three? As everyone i'm looking to make a lot of power(and a lot under the curve). If you could go to a slightly smaller turbo now would you? I dont want a laggy turbo!
boss block, tko, turbo, lots of go
95cobra50 is offline
post #2 of 7 Old 09-07-2007, 02:54 PM
I used to run the MP T70 with a .96 but it was on a 351w. It spooled well and was perfect for the combo. Made over 500whp and 617rwtq. However on a 302, even with heads and intake I would most likely go with smaller. I know MP makes a .84 a/r turbine housing. I would look into that. If your stock or close to it....68 is the way to go, but it will choke up top once mods are made. Good luck
65 Mustang
68 Barracuda 440
boostdidfox is offline
post #3 of 7 Old 09-07-2007, 08:37 PM
1995gtCPE's Avatar
Trader Feedback: (34)
MP only makes a .68 and .96.
1995gtCPE is offline
post #4 of 7 Old 09-08-2007, 02:13 PM
93gtman's Avatar
Trader Feedback: (21)
yeah they stoped making the .81
NY
93gtman is offline
post #5 of 7 Old 09-09-2007, 09:25 PM
friend had .81 on a 302 ported gt40p heads,ported perf rpm intake,70mmtb meth injection 10.5psi 489rwhp 14psi split the block 2 times
.68 will take about 600whp ten its runing out of steam
.96 for bigger than 302ci
lov2xlr8 is offline
post #6 of 7 Old 09-09-2007, 11:34 PM
Interesting...shows how long since I have looked at MP's. Thanks though.
65 Mustang
68 Barracuda 440
post #7 of 7 Old 09-14-2007, 04:41 PM
go with the .68. That's what i was running on my 89 mustang 302 and got full spool around 3000-3200rmp.
.96 wouldn't be until after 4000 which suck ass for street but not bad for track.
arnold22 is offline
