T70 vs. T-trim dyno graph - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 09-05-2007, 06:26 PM Thread Starter
I finally got the car tuned today. I had Monty do a over lay of my old setup when I was running a T-trim. Here are the different combos.
T-trim 3.00, AFM power pipe, 5.4 crank pulley, Snow kit, 8 rib, BAS, stock heads/cams/intake, built bottom 10cc piston 9-1 compression. 80mm Pro-M. BBK long tubes, off-road H pipe, MAC catback, 60 injectors, twin 255 inline AN 8 to the rails AN 6 return, UPR fuel rails. It saw 17psi on the dyno, 20 psi on the street. 17 degrees timing. (red line)
Turbocharged innovations custom 4v kit (Magicbus), T70 Master power turbo, Tial 38mm gate 14 psi spring, 3 inch piping, custom intercooler, same engine as above (stock heads/cams/intake) MAC catback. PMAS HPX. The Maf readings were about 900 counts so it has 100-150 hp in it before it pegs. AIT temps never got above 112. (blue line)
http://i167.photobucket.com/albums/u...t70vsttrim.jpg
Forged Short Block, Stock heads, cam, intake
Single MP T-70 Turbo
turbochargedinnovation.com
sc96cobra is offline
post #2 of 15 Old 09-06-2007, 02:41 AM
slo5.0.'s Avatar
sweet... looks like you made alot more power sooner also for longer period it held.. what was the TQ diff?
slo5.0. is offline
post #3 of 15 Old 09-06-2007, 08:46 AM Thread Starter
we couldn't get a good tach signal, but it was well into the 500+ range.
post #4 of 15 Old 09-06-2007, 10:13 AM
smurfmobile8586's Avatar
anyway to post the dyno sheet?
smurfmobile8586 is offline
post #5 of 15 Old 09-06-2007, 01:29 PM Thread Starter
click the link on the bottom of the first post.
post #6 of 15 Old 09-06-2007, 03:43 PM
ATOMonkey's Avatar
Can you feed rear end ratio and tire size into the computer to back out RPM and Torque?
What kind of boost are you running with the turbo? Same as the T-trim?
"Let the little children come to me, and do not hinder them, for the kingdom of God belongs to such as these." - Mark 10:14-15
RIP 'Meli
April 28th 2009
ATOMonkey is offline
post #7 of 15 Old 09-06-2007, 05:25 PM Thread Starter
14 psi on turbo
17 psi on the dyno 20 psi on the street with the t-trim
The other question I have no ideal on.
post #8 of 15 Old 09-07-2007, 09:26 AM
ATOMonkey's Avatar
What tire size and gear ratio are you running? I can try to put some points into excel and see if I can come up with something.
I'm trying to map out engine performance for B heads for someone and this data is very helpful in verifying my calculations.
RIP 'Meli
April 28th 2009
post #9 of 15 Old 09-07-2007, 01:06 PM
duh.. thanks i never saw it
post #10 of 15 Old 09-07-2007, 02:29 PM
slo5.0.'s Avatar
Heres also a t-70 vs a S trim both on 15 psi.
slo5.0. is offline
post #11 of 15 Old 09-09-2007, 09:30 PM
god dam ta turbo makes a #### load more torque
lov2xlr8 is offline
post #12 of 15 Old 09-10-2007, 10:07 AM
Trader Feedback: (-1)
ooooooo i love turbos...
turbod04gt is offline
post #13 of 15 Old 09-11-2007, 03:46 PM Thread Starter
__________________
3.27 and 315/35/17 tires. Let me know the results, thanks.
post #14 of 15 Old 09-18-2007, 01:23 PM
ATOMonkey's Avatar
Here is a graph of what your TQ and HP would look like.
I can send the excel file if you want.
It's not exact, because nothing is as accurate as a spark source, but it's close enough for government work.
RIP 'Meli
April 28th 2009
post #15 of 15 Old 09-18-2007, 08:14 PM Thread Starter
thanks
