WHo builds custom turbo kits.My way. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 24 Old 08-30-2007, 11:51 PM Thread Starter
I live in the midwest and have been looking into turbos for a fox body.I have looked at some different companies and it seems there is something about each one that I dont like.Cant see spending big bucks when the fit is not quite right.Who in the midwest builds custom kits.
Brian 90 is offline
post #2 of 24 Old 08-31-2007, 12:35 AM
slo5.0.'s Avatar
Newt at quicktimeturbosystems.com Im sure can accomidate you in anyway. Just call him go to the website.
slo5.0. is offline
post #3 of 24 Old 08-31-2007, 01:30 AM
Trader Feedback: (101)
B/G Custom Turbo Fabrications....enough said.
papis408 is offline
post #4 of 24 Old 08-31-2007, 08:33 AM
93gtman's Avatar
Trader Feedback: (21)
+1 for B/G TOO!
NY
93gtman is offline
post #5 of 24 Old 08-31-2007, 09:26 AM
millhouse's Avatar
Originally Posted by 93gtman View Post
+1 for B/G TOO!
+2
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #6 of 24 Old 08-31-2007, 12:02 PM
Erich's Avatar
DIY?
Erich
Erich is offline
post #7 of 24 Old 09-02-2007, 12:57 AM
lethl-lx's Avatar
QuickTime Turbos!!!!! Is all you need
I have one on my car and Ive had zero problems with fitting . This thing fits like a glove, and this thing makes badass power ... And you won`t find anyone with a better customer service .. Then with Newt-Rod ...
91LX Vert 306 Winsor Sr. heads ,42lb inj , 70mm Accufab TB Typhoon intake ,TFS Stage 1 cam
70mm Turbo kit
lethl-lx is offline
post #8 of 24 Old 09-02-2007, 10:49 PM Thread Starter
I am looking for a complete bolt on system. Quicktime has not got back to me yet after my inquire.I want a draw through system.I would also like to keep smog.Draw through main concern.
Brian 90 is offline
post #9 of 24 Old 09-02-2007, 11:55 PM
PTK makes a draw thru kit, but I've heard horror storie about their
customer service and delivery time.
Nothing wrong with Blow thru MAF meters as long as it has
nice straight path of at least 8" before meter
You could also make any turbo kit Draw thru with a little common
sense modifying
r.barn is offline
post #10 of 24 Old 09-03-2007, 07:24 PM
Trader Feedback: (38)
Quick time turbo X100000000000000, i must say the best fitting kit i have owned, and best to deal with, and get a hold of unlike some that have been mentioned above, everything it top notch
Thank's again Newt
1988 notch
erich306 is offline
post #11 of 24 Old 09-07-2007, 09:22 PM
Another one for Quick Time. Kits are worth more than he sells them for. Get you a meter from PMAS setup for blowthru and your all ready.
88hatch 5.0
93Lightning turbo
2015 GT
dynoman is offline
post #12 of 24 Old 09-07-2007, 09:35 PM
MCLFLN's Avatar
Location: Taylorville, Illinois, United States of America
I highly recommend Rob Lasota:
http://www.lasotaracing.com/
MCLFLN is offline
post #13 of 24 Old 09-08-2007, 12:39 AM
smurfmobile8586's Avatar
+3 on quick time
smurfmobile8586 is offline
post #14 of 24 Old 09-08-2007, 10:32 AM Thread Starter
Well I am waiting to hear back from Newt at quicktime.
Brian 90 is offline
post #15 of 24 Old 09-08-2007, 11:04 AM
Unless something has changed, the PTK kit will not let him keep the smog that he said he would like to keep.
post #16 of 24 Old 09-08-2007, 01:09 PM Thread Starter
I am aware that only the Hellion allows you to keep smog pump.
Brian 90 is offline
post #17 of 24 Old 09-08-2007, 02:32 PM
Cartech and TTI both have allowed you to keep the smog pump and been that way for probably well over a decade now. There is a small turbo kit company up in your neck of the woods called Turbotime PSI out of Chicago area that it too allows you to keep the smog. Probably other companies as well, definitely is not limited to Hellion.
post #18 of 24 Old 09-11-2007, 03:58 PM
93Svt331's Avatar
your in il...why do you need the smog pump??
90 lx, 408w, T56, 88mm
93Svt331 is offline
post #19 of 24 Old 09-11-2007, 04:20 PM
Technically you need it everywhere since it is a federal law that you have them. But if people are worried about federal laws then they best not be doing a lot of the things they do to a Mustang to put a turbo on it. If I lived somewhere that did not check for them, I personally would have a kit that keeps it for just in case if I ever moved to a place that checks them. What advantage does one get by having a kit that does not allow one to be there at all? If it allows one to be there, it does not mean you have to run it.
post #20 of 24 Old 09-11-2007, 05:30 PM
93Svt331's Avatar
IL doesn't have emissions for these cars anymore...
93Svt331 is offline
post #21 of 24 Old 09-11-2007, 08:37 PM
The states can not make a law that overrides a federal law. I bet Il just does not require emissions checking on these cars anymore, much like several other states.
post #22 of 24 Old 09-11-2007, 11:54 PM Thread Starter
Being able to run the smog pump is just a preference of mine.I know smog pumps are kind of a joke but in some areas they are a necessity.
Brian 90 is offline
post #23 of 24 Old 09-22-2007, 10:36 PM
SilverSmith82's Avatar
Trader Feedback: (28)
B&G, Ponydown, Quicktime...seriously there is nothing wrong with ANY of these systems I have no clue wth you could find wrong with any of these guys.
-2000 Mustang GT Steeda #0048. 4V swapped, FTBR IRS, Steeda factory suspension, Ultralites, VRS X, "Exhaust Shop Special" catback.
Stock 2V computer rewired for 4V, Tuned by James Gordon.
SilverSmith82 is offline
post #24 of 24 Old 09-27-2007, 05:32 PM
blow thru is way better. i have a vortech on a 02 gt and i went ahead and switched it to a blowthru and an intercooler. driveability is a lot better plus i was able to pull more fuel from the other tune.
blowthru is the way to go IMO
fearsjohn is offline
