BOV - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 08-29-2007, 01:58 PM Thread Starter
Scones's Avatar
BOV
ok, this may sound dumb to a lot of you, especially froma guy like me who has been playing with turbo cars since 96 but i have never run a BOV before. i just picked up a cheap one from ebay hoping that it might help solve my problem with IC hoses blowing off. i see nowhere to adjust it - is it just a plug and play kind of thing? i keep seeing people posting about adjustable bovs and i'm a bit confused. anyone want to shed some light?
1986 5.0TT Tribute Car
2010 Ranger 4.0
1989 Kawasaki Ninja ZX6
Scones is offline
post #2 of 7 Old 08-29-2007, 02:06 PM
ARCANGL's Avatar
Trader Feedback: (76)
not all are adjustable... some just have a vacuum plug in and thats about it. I think alot of bypass valves are built this way.
ARCANGL is offline
post #3 of 7 Old 08-29-2007, 11:13 PM
i had one from ebay it would not blow off for anything so i took the internal spring out replaced it with an weaker wastegate spring and it works great now but when it wasnt working i was blowing my ic pipes of and they are t bolted on.
wht89gt is offline
post #4 of 7 Old 08-30-2007, 07:20 AM
Erich's Avatar
Yep-those cheap ones like the famous plasic bosch ones have no adjustments on them. Just a vacuum line plus an inlet and outlet.
For tubes blowing off, you can put a dot of weld on the end of the tube. Actually two dots approx 180 degrees from each other. That will give the clamp something to bite. Are you using proper Tbolt clamps?
Erich
Erich is offline
post #5 of 7 Old 08-30-2007, 09:06 AM
strokercharged95GT's Avatar
put some hair spray on the piping before slipping on the silicone and bolting it down. It helps the silicone grip the piping much better.
2013 Mercedes GLK-350
strokercharged95GT is offline
post #6 of 7 Old 08-30-2007, 09:56 AM
millhouse's Avatar
Erich
+1
I actually ran without a BOV the first year I had my setup and had no issues blowing off intake hoses. T-bolt clamps + welded beads (or bead rolled) ends should do the trick.
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #7 of 7 Old 08-30-2007, 03:12 PM Thread Starter
Scones's Avatar
Well, it's not the cheapest bov, but it wasn't pricey either. Some place here in Ontario makes it...seems like a forge knock-off. I think I solved my ic hose problem by taping my pipes together with aluminum ducting tape before sliding the coupler over. Can't weld a lip...remember I'm using abs piping lol.
Anyway, here's the valve....
http://cgi.ebay.ca/ws/eBayISAPI.dll?..._promot_widget
2010 Ranger 4.0
Scones is offline
