Which catback for Turbo 5.0? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 08-27-2007, 10:32 PM Thread Starter
Trader Feedback: (40)
I have a '90 notch 5.0 5-spd with a Quick Time 70mm turbo kit. Bernard fabbed up a y-pipe for me with V-band connections which will get me close with a aftermarket h-pipe. Is there a good 3" catback for a turbo car or will I have to piecemeal one together?
'90 black notch 302 TFS TH kit TKO600 Mcleod scattershield 8.8 with Quicktime Turbo power!
Supernotch is offline
post #2 of 12 Old 08-28-2007, 07:38 PM
Blackfive0's Avatar
Trader Feedback: (62)
I had trouble finding one for my notch when I got my turbo car going I ended up going with a 2.5" maga flow cat-back. Good luck
Blackfive0 is offline
post #3 of 12 Old 08-29-2007, 12:39 AM Thread Starter
Thanks for the advise. What did you use for the mid-pipe?
Thanks again in advance.
post #4 of 12 Old 08-29-2007, 01:26 AM Thread Starter
Actually a better ? to ask is do I need a 2.5" or 3" catback?
Engine:
stock 88 GT shortblock
TFS Track Heat heads
Holley Sys intake
70mm turbo
TKO 600
post #5 of 12 Old 08-29-2007, 09:11 AM
3" is what you'd want....
TFScoupe is offline
post #6 of 12 Old 08-30-2007, 01:50 PM Thread Starter
Is there a 3" catback available aside from the Flowmaster and MAC chambered muffler kits?
post #7 of 12 Old 08-30-2007, 02:27 PM
They have this choice
http://www.performance-curve.com/ind...OD&ProdID=1060
and others, but I haven't tried any of them.
Sorry, it just sank in that you asked about complete catback sytems... not just a bare cat.
JimS is offline
post #8 of 12 Old 08-30-2007, 03:07 PM
93gtman's Avatar
Trader Feedback: (21)
i wonder if i should go with a 3'' single ? i think i would miss the dual look.
for now i am going to use my mac 2 1/2'' cat back with a y-pipe then eventually get a non-chambered setup which is better and less restrictive for a turbo setup. But i would like one that is not loud while cruising and idle just under WOT
NY
93gtman is offline
post #9 of 12 Old 08-30-2007, 07:05 PM
I am running a 3" single hooker max flow. If I recall two 2.5" are equal to a single 3.5" and two 2.25s are equal to a single 3". If you want to keep duals and just want a catback setup I would get the magnaflow. If you want a single 3" then there is some information out there on them.
The results in HP order:
1.Flowtech Warlock (open) 374.2 hp/ 333.1 tq
2.Bassani Real Street 373.7 hp/ 333.8 tq
3.Hooker Maxflow 373.5 hp/ 333 tq
4.Borla XS 373.3 hp/ 332.6 tq
5.Magnaflow 372.8 / 332.5 tq
6.MAC 372.3 hp / 331.5 tq
7.Flowtech Afterburner 372.3 hp/ 330.1 tq
8.Hooker Aerochamber 372.1 hp/ 330.4 tq
9.Bassani 372 hp/ 333.5 tq
10.Spintech 371.6 hp/ 332.2 tq
11.Edelbrock Performer RPM 370.9 hp / 331.3 tq
12.Borla XR1 370 hp/ 334 tq
13.Flowtech Terminator 369.5 hp / 331.3 tq
14.Dynomax Ultra Flo 369.4 / 333.2 tq
15.Flowmaster 369.4 hp / 331.8 tq
16.Flowtech Warlock 366.3 hp / 325.3 tq
17.No muffs 365.2 hp / 330.1 tq
Sound Off in Quietest to Loudest (Decibels):
1.Borla XS, 80db at idle, 90db at 2,000 rpm, 110db at WOT.
2.Hooker Maxflow, 80db at idle, 90db at 2,000 rpm, 120db at WOT.
3.Magnaflow, 82db at idle, 91 at 2,000 rpm, 114db at WOT.
4.Flowmaster, 82db at idle, 93 at 2,000 rpm, 115db at WOT.
5.Flowtech Warlock, 83db at idle, 92 at 2,000 rpm, 112db at WOT.
6.Dynomax UltraFlo, 83db at idle, 94 at 2,000 rpm, 113db at WOT.
7.Borla XR1, 83db at idle, 96db at 2,000 rpm, 118db at WOT.
8.Bassani Street, 83db at idle, 96db at 2,000 rpm, 120db at WOT.
9.Edelbrock RPM, 84db at idle, 93db at 2,000 rpm, 118db at WOT.
10.Bassani Real Street, 84db at idle, 96db at 2,000 rpm, MAX. (120+db).
11.Flowtech Afterburner, 86db at idle, 94db at 2,000 rpm, 115db at WOT.
12.Flowtech Terminator, 86db at idle, 94db at 2,000 rpm, 119db at WOT.
13.Hooker Aerochamber, 87db at idle, 94db at 2,000 rpm, 114db at WOT.
14.SpinTech, 87db at idle, 97db at 2,000 rpm, 116db at WOT.
15.MAC, 87db at idle, 98db at 2,000 rpm, 119db at WOT.
16.No Muffler, 91db at idle, 103db at 2,000 rpm, MAX. (120+db).
1994 Turbo GT
mustangless is offline
post #10 of 12 Old 08-30-2007, 09:54 PM
93Svt331's Avatar
Trader Feedback: (38)
^^ nice info
90 lx, 408w, T56, 88mm
93Svt331 is offline
post #11 of 12 Old 08-31-2007, 02:20 PM
biminiLX's Avatar
You'd be fine at 2.5" with those parts. If you already have the MAC CB and like it, just weld in some straight through mufflers. BTW, I loved my Borla ProXS on my '04 Cobra.
-J
'91 LX hatch
Bimini Blue
427"/88mm at 16 psi
biminiLX is offline
post #12 of 12 Old 08-31-2007, 03:03 PM
Not my thread.... but I'm glad to hear you like the ProXS since I have a couple to install once I'm ready. The only bummer is I bought the 3" versions, and while they do have a 3" inlet/outlet, they still neck down internally to 2.5". Kind of a cheap trick.
JimS is offline
