Blow Thru Meter ....Help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 08-22-2007, 03:43 PM Thread Starter
Trader Feedback: (36)
I've got 30's in my car now with a blow thru Pro-M setup and I just purchased some 42's and a Pro-m but the meter is calibrated for N/A.....I have a turbo car. Can I use it?.......and does anyone know the calibrations differences? I know the best thing is to get it correctly calibrated, but for time being will it be OK......Thanks
scotng is offline
post #2 of 5 Old 08-22-2007, 05:58 PM
Not to hijack your thread do u know if u can use a standard meter as a blow through is it actually a different meter or is it just terminology?
wht89gt is offline
post #3 of 5 Old 08-22-2007, 06:09 PM Thread Starter
Won't swear to it.....but I've heard of guys using a standard as blow thru.
scotng is offline
post #4 of 5 Old 08-24-2007, 03:36 PM
You don't mention anything about the calibration of the new meter, just that the other meter was used on a car with 30's in it. This is the main issue you need to address, making sure it is cal'd to 42's, or another tuning device that fixes this incorrect MAF transfer function.
I have seen N/A meters used a blow-through (think LMAF). The biggest key to running a MAF vehicle in draw or blow-through period is having as much straight, same diameter tubing/piping with no bends or kinks of any kind for as long of a distance as possible before the meter and at least a few inches afterwards.
87'GTstang is offline
post #5 of 5 Old 08-24-2007, 08:08 PM
If I recall, people who use tweecer say get a N/A meter. It has 15% more left before it pegs than another meter. I would think you would be after a tune. But without a tune I would not be sure.
1994 Turbo GT
mustangless is offline
