headgasket question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 08-02-2007, 02:03 AM Thread Starter
headgasket question
Alright this question may be completely nooby, but I never can really find any good info on the matter.
Why is it i hear about so many turboed 5.0 head gaskets failing.. this is one of the things holding me back from a turbo system (that and losing the flawless mustang exhaust sound). Why do the gaskets blow?
I would seriously shoot something if I spent all the money and time getting a turbo kit installed and blow a headgasket
How is changing the sparkplugs on a turbo setup?
1994 Lazer Red GT Vert :: Bilsteins :: mach springs :: MM lower control arms :: MM subframes :: 03 Cobra A-arms :: Cobra brakes :: 03 cobra steering shaft:: Aluminum DS :: Pulleys :: CAI :: Bassani O/R system :: 3.55 gears
ponypowa2 is offline
post #2 of 9 Old 08-02-2007, 08:55 AM
slowstang101's Avatar
do some research
Dart Blocked SBF, PT106mm, Callies Magnum Crank, Oliver billet rods. New top end package in the works
slowstang101 is offline
post #3 of 9 Old 08-02-2007, 09:48 AM
U.S. Air Force RETIRED
Matt Grieve's Avatar
Trader Feedback: (88)
knock on wood I haven't popped one yet...most gaskets fail from a lean condition or getting to greedy with timing on pump gas...
I run Fel Pro 9333PT1 gaskets and have worked well for me and anyone I know who runs them on S/C, Nitrous, and turbo cars
1990 Mustang GT
2004 Mystichrome Cobra
2015 Mustang Ecoboost
2015 RAM 2500 Cummins
Matt Grieve is offline
post #4 of 9 Old 08-02-2007, 11:02 AM
strokercharged95GT's Avatar
Because people who buy turbo are those that arent even satisfied with enough horsepower NA. So all the people who want crazy horsepower are the people who tend to push their combos. People who push their combos and run trubo usually have a high tendancy for engine failure. Headgaskets usally blow becuase someone gets agressive on their tune, which figures into the people with turbos. changing spark plugs on the passanger side of a single turbo is a real PITA (assuming yours is on that side).
BTW im bolting on a t66 to a 10.5:1 compression motor as we speak. Im hoping to keep it together to start at 6 psi then work my way up. I give it 50/50 that Ill blow a headgasket in the first month.
2013 Mercedes GLK-350
strokercharged95GT is offline
post #5 of 9 Old 08-02-2007, 11:36 AM
Headgaskets blow and pistons break from a bad
or over aggressive tune .............. period
most people also use cheap headgaskets so at the first ping
they blow right out.
r.barn is offline
post #6 of 9 Old 08-02-2007, 01:13 PM
Erich's Avatar
You get alot with a turbo setup. It does put a strain on a stock setup. You can easily start lifting heads with stock headbolts. I think ARP studs plus 9333pt1 felpros combined with a good tune and you are good to go. But as you mess with turbo or forced induction stuff, you need to be open to the idea of replacing headgaskets/pistons/etc. Comes with the territory. Your motor will be doubling its intended hp and torque. You don't get aught for naught.
As far as plugs go-I would think it depends alot on the turbo setup. On my homebuilt one with P heads, it is not that bad on the passengerside-so long as you replace them from under the car. No way could you do it from the top.
The real pain is replacing headgaskets when you have to take all the turbo stuff off in addition to everything else.
Erich
Erich is offline
post #7 of 9 Old 08-02-2007, 01:45 PM
I have not blown a gasket, and made about 7 track passes and 2500 hard miles running 13.2 afr
1994 Turbo GT
mustangless is offline
post #8 of 9 Old 08-02-2007, 03:58 PM
Blackfive0's Avatar
Trader Feedback: (62)
I myself have had zero head gasket problems. I use fel-pro 9333 pt1, ARP head studs and a good SCT turn form Bob Kurgan. Car sees about 14psi. A lot of it has to do with the tune, but Heads studs over bolts does help to.
As for changing spark plugs, will that depends on the kit you have
Blackfive0 is offline
post #9 of 9 Old 08-02-2007, 04:58 PM
fred50stang's Avatar
I have the FRPP 1011-2(or the -1 i forget) which is a fel-pro gasket. 15lbs of boost. No problems.
I have the hp turbo, and changing plugs or checking them is fairly easy.
fred50stang is offline
