Need Help vband clamps leaking - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 08-01-2007, 06:26 PM Thread Starter
I bought a used turbo kit and were the headers come together with a vbang clamp leaks also were the turbo and downpipe come together leaks has anybody had this problem and how did you fix it?
tangsc is offline
post #2 of 5 Old 08-01-2007, 06:43 PM
lethl-lx's Avatar
Try using some high temp silicone on the flange , Just use a skim layer on it ..
91LX Vert 306 Winsor Sr. heads ,42lb inj , 70mm Accufab TB Typhoon intake ,TFS Stage 1 cam
70mm Turbo kit
lethl-lx is offline
post #3 of 5 Old 08-01-2007, 09:56 PM
staticstang's Avatar
Word.....also v-band clamps will sometimes leak until they get some heat into them before they seal up.
staticstang is offline
post #4 of 5 Old 08-02-2007, 02:03 PM
my v-bands leak on my crossover too. I tighten them, drive and it does fine. I guess after it cools off they come lose, because when I start it next time it is bad again. This has happened the last 2 times it was driven.
1994 Turbo GT
mustangless is offline
post #5 of 5 Old 08-02-2007, 10:52 PM
blown8950's Avatar
Like lethal-lx says, just get some high temp Permatex (red) and smear a little on the flanges where they fit together. Let it get tacky then assemble and tighten. When it gets hot, retighten.
1989 LX: Vortech YS-Trim blown DSS 347, Stage 3 Twisted Wedges, Holley Systemax 2, AFM B-451 cam, AFM Power-Pipe, AFM PMS, 80mm Pro-M, Aeromotive 1000 hp fuel system, Precision Turbo 65 lb/hr injectors, UEGO 1000 Wide Band O2, MSD 6BTM and Distributor, 33-spline Moser axles and spool, Bogart Drag-On Stars, UPR Chromemoly K-member and A-Arms, Kooks 1-7/8", Dr. Gas, 130 amp alt, etc.
1991 GT Convertible: stone stock, PA AOD, Edge Converter, 62mm Turbo, 397 rwhp, 458 lb./ft rwtq @ 8 psi
blown8950 is offline
