where can i get - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 07-16-2007, 12:50 AM Thread Starter
where can i get
Where can i get oil line and the thing that hooks up to my sending unit to oil my turbo?
wht89gt is offline
post #2 of 8 Old 07-16-2007, 11:09 AM
Trader Feedback: (38)
you can get a t at any place like home depot i think it's 1/8 inch but could be 1/4 and as far as line you could use some -4 with the correct fittings on both ends, to do it right, you you could make some thign home made with some rubber hose with barbed fittings and some hose clamps
1988 notch
erich306 is offline
post #3 of 8 Old 07-17-2007, 10:04 AM Thread Starter
Isnt threr a special fitting that hooks to the sending unit to push oil to the turbo?
wht89gt is offline
post #4 of 8 Old 07-17-2007, 10:26 AM
I just drilled/tapped the sending unit bar that screws into the block. I left my stock oil pressure sensor in place. I then put in a couple of -3(or maybe -4, I forget) AN fittings, screwed them in. Then I hooked up my lines from the turbo to that fitting and from my gauge in the car to the other fitting.
post #5 of 8 Old 07-17-2007, 10:50 AM
millhouse's Avatar
I did something similar. I drilled and tapped some 1/4" NPT holes on the bar and attaches a couple of 90* 1/4" NPT to -4AN fittings.
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #6 of 8 Old 07-17-2007, 08:59 PM Thread Starter
Can anyone send or post some pics.
wht89gt is offline
post #7 of 8 Old 08-06-2007, 11:32 PM
93Svt331's Avatar
subcribing
90 lx, 408w, T56, 88mm
93Svt331 is offline
post #8 of 8 Old 08-07-2007, 01:08 PM
http://treadstoneperformance.com/view.phtml?f_cat=Oil
oil feed and return lines and fittings
r.barn is offline
