sorry for asking...... how much boost can a stock 5.0 block handle? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 17 Old 07-03-2007, 12:49 AM Thread Starter
Moderator
eleanorfox's Avatar
Trader Feedback: (57)
ive searched everywhere and cant find the answere.
2001 Mustang GT Bullitt (terminated) #2793
2015 GMC Sierra 1500 4x4
2015 Chrysler 300 S
eleanorfox is offline
post #2 of 17 Old 07-03-2007, 01:10 AM
Trader Feedback: (22)
25lbs
turboLXstang is offline
post #3 of 17 Old 07-03-2007, 07:12 AM
Erich's Avatar
It is not a question of boost, it is horsepower and tune. There are many factors that go into the equation. There is no simple answer. Better to ask a different question like: How much hp do I want to make? Then what do I need to make that? If your setup is not reving over 5500-6000 you will likely have a longer life. The rule of thumb is somewhere around 450 to 500 hp you start to enter a danger zone of blocks cracking. However, there are many examples of higher hp where things are fine (see Moovs for example). Most likely thing to happen is to blow headgaskets on 302s. Gotta have a good tune.
Erich
Erich is offline
post #4 of 17 Old 07-03-2007, 11:11 AM
It's about these things.......1) tune i.e. timing & fuel 2) How well is the balance on the rotating assembly? 3) Keep the rpm's under 6K.....
A main girdle helps a bunch too....
TFScoupe is offline
post #5 of 17 Old 07-03-2007, 01:35 PM
Also, as a rule of thumb its hard to exceed 15psi on pump gas
with out building from the ground up for it.
Yes, you hear lots of Cobra guys running more, but they are
also breaking shyt too.
r.barn is offline
post #6 of 17 Old 07-03-2007, 02:01 PM Thread Starter
Moderator
eleanorfox's Avatar
i want at least 600whp. and i want to do it right i just want to know wether its worth building a badass shortblock to handle boost and hp. from a stock block. i was thinking about just going with a shortblock from like D.S.S racing whiich ive heard that they use stock ford blocks. or CHP performance. what do you guys think.
2015 Chrysler 300 S
post #7 of 17 Old 07-03-2007, 02:06 PM
Erich's Avatar
If you want 600 and have the cash go with a one of the new Boss blocks, Dart or manowar. All will allow room to grow from the 600 plus you can get thicker headstuds etc with way more block strength.
Erich
Erich is offline
post #8 of 17 Old 07-03-2007, 02:18 PM Thread Starter
Moderator
eleanorfox's Avatar
i would one of those dss shortblocks hold up? with the right tune and every precaution takin nessacery? btw i run a carb if that mattered
2015 Chrysler 300 S
post #9 of 17 Old 07-03-2007, 02:20 PM
+1 get a Dart block for that kinda power if you want it to last
with no worries
600rwhp = 700-800hp engine, stock block no matter how good
the internals will be suspect.
r.barn is offline
post #10 of 17 Old 07-03-2007, 02:22 PM
I have a friend making 790rwhp on DSS stock "pro" build up 347
but its going to break, ....... sooner or later.
DSS shortblocks are just stock blocks, stud girdles do NOT strengthen
block they just help with crank walk at high rpms
If you want it to last you're going to have to invest in a DSS XR block
r.barn is offline
post #12 of 17 Old 07-04-2007, 02:42 AM Thread Starter
Moderator
eleanorfox's Avatar
i did search but i dont think i searcged the right words cuz those didnt show up thanks a lot though
2015 Chrysler 300 S
post #13 of 17 Old 07-04-2007, 03:54 AM
You could always use a 351 block. good for 600+
2003 GT, Vortech, LT's, etc
jerrad is offline
post #14 of 17 Old 07-04-2007, 09:02 AM
If your goal is 600rwhp then I would start with a different block, If your goal was 500rwhp then I would stay with the stock one.
I know DSS does all the best machining techniqes but under it all it's still a thin wall stock block.
I don't think girdles help that much, rpms and tune are the factors I believe.
JMO
MOOVS is offline
post #15 of 17 Old 07-04-2007, 09:46 AM
privatejoker's Avatar
What do you guys consider to be a safe tune? Is it just zero detonation?
privatejoker is offline
post #16 of 17 Old 07-04-2007, 11:30 AM
slo5.0.'s Avatar
5500 rpm max and 0 detonation helps.
slo5.0. is offline
post #17 of 17 Old 07-04-2007, 02:44 PM
zero det. and a safe a/f ratio, 12:1 or under.
MOOVS is offline
