car feels slow - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 06-23-2007, 05:27 PM Thread Starter
car feels slow
well im still working out some kinks with my setup
but 1st and 2nd are slow like it takes to long to spool up
but 3td and 4th pull hard could the this be cause of my 373
rear end i just thought i would have more tourqe any ideas
my set up
306
hci
t 70 .68
60 lbs injectors
70mm tb
255 in tank in line fuel
pup50 is offline
post #2 of 5 Old 06-24-2007, 03:56 PM
slo5.0.'s Avatar
curious to know to.. I wouldnt say the rear end. Or a bad clutch because its find in bigger gears. Kinda weird hopefully we can see what it is.
slo5.0. is offline
post #3 of 5 Old 06-25-2007, 08:58 AM
qikazz's Avatar
my set up
306
hci
t 70 .68
60 lbs injectors
70mm tb
You need to get the car to a tuner, get it on a dyno and see what it is doing in the Air/Fuel and timing areas. You may also have a boost leak somewhere. Do you have a boost gauge on the car? If so, how much is it showing?
I will tell you this, with that 70mm turbo, and especially that .68a/r on the hotside, that thing should spool INSTANTLY and should blaze the tires in at least the first three gears.
qikazz
qikazz is offline
post #4 of 5 Old 06-25-2007, 09:06 AM
i agree with qikazz. I had a H/I 302 with a T67 .68 and i had 15 psi by 2400 rpms in fourth LOL. Thing made stupid torque. Get it to a tuner and you should find you're answer.
fastwhite86gt is offline
post #5 of 5 Old 06-25-2007, 05:00 PM Thread Starter
ill make a app tomorrow for the tune . my boost gauge shows around 12-15 like i said 3 and4 are pretty fast tires want to break loose aroun 3500 to 4000rmp im running mt dr 26 10.5 16
pup50 is offline
