Race Fuel ?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 06-19-2007, 12:18 PM Thread Starter
Race Fuel ??
I'm running a 4v motor with a T76. On 93 octane I have it tuned at 15 lbs. of boost. How much boost could I safely add if I switched to race fuel?
Hellion'01 is offline
post #2 of 9 Old 06-19-2007, 12:40 PM
If I remember right its like 2pts of octane per 1psi of boost.
so 5 more psi would need 10 more octane points
100octane and 20 psi should be ok.
wouldnt go much past 20psi on a street engine, thats alot of boost
r.barn is offline
post #3 of 9 Old 06-19-2007, 09:57 PM
Alot will depend on compression and timing too. In my turbo buick 15-16 on 93 and with race gas I've seen people put 24-26. Granted thats for a motor built for boost and a tune thats low on timing. Also, depending on the car you might want to add timing with the race gas. Some cars will like more timing than more boost.
2003 GT, Vortech, LT's, etc
jerrad is offline
post #4 of 9 Old 06-19-2007, 10:07 PM Thread Starter
It is a built motor but has stock (9.8-1) compression. Right now it is topped out at 18 degrees of timing.
post #5 of 9 Old 06-19-2007, 11:23 PM
nyctry96's Avatar
subscribing. I'm in a similar delima. To switch to race fuel or not to switch?
Bump for ya
96 TT Cobra, Dave Zientera Racecraft 8pt cage w/dual swingouts. Big Stuff 3, C-4 auto
nyctry96 is offline
post #6 of 9 Old 06-19-2007, 11:38 PM
you can use alcahol(sp). I have alky on my buick but I'm o retarded to tune it so I don't knock but still don't run as good as it should.
jerrad is offline
post #7 of 9 Old 06-20-2007, 06:13 AM Thread Starter
I really don't know enough about alky to even consider switching and trying to tune it at this point, other than I'd have to dump a lot more fuel in it which means bigger injectors. And bigger injectors means switching to a low impedence driver and I'm not really wanting to go that route yet.
post #8 of 9 Old 06-20-2007, 06:29 AM
Alky will make up for your lack of injector. I bought my kit for Julio at www.alkycontrol.com so you might give kit a call.
jerrad is offline
post #9 of 9 Old 06-20-2007, 10:40 AM
+1 a SnowPerformance "Boost Cooler" water/meth injection
system will give you what you are looking for with out the
expense and hassle of race gas.
Most people just use window washer fluid for their water/meth
spray too, cost about $1/gal
r.barn is offline
