0.96 A/R HP Performance turbine housing - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 06-11-2007, 12:43 AM Thread Starter
bikewiz's Avatar
Trader Feedback: (18)
Hey guys,
HP screwed up when they were sending me the parts for my stage II kit, first they shorted me my turbine housing, then I got 2 of them. Didn't want to make a formal post for sale cuz I don't have a picture uploaded on this computer, but if you have a big cube motor (i.e. 347 or 351) and you have or are getting an HP Performance turbo kit, PM me and I can sell you this better flowing 0.96 A/R turbing housing thats a decent upgrade from the 0.68 A/R that comes with the kit. It is still brand new in the Jet-Hot box.
Matt
bikewiz is offline
post #2 of 8 Old 06-11-2007, 07:59 PM
Blackfive0's Avatar
Trader Feedback: (62)
Your Stage II is has a .96 A/R?
So is the .68 what comes with the Stage I? Because I have the stage one kit will that is what I bought and I have a .96a/r on my turbing housing. Just wondering if they sent me the wrong one.
Blackfive0 is offline
post #3 of 8 Old 06-11-2007, 09:48 PM
i have a stage one turbo and it has the .96
1994 Turbo GT
mustangless is offline
post #4 of 8 Old 06-11-2007, 10:21 PM
GTmustang00's Avatar
you can order the housing size you want w/ either kit i believe
98 Chrome Yellow cobra 9800 miles
1989 Mustang GT, modified to hell
GTmustang00 is offline
post #5 of 8 Old 06-11-2007, 11:02 PM Thread Starter
bikewiz's Avatar
It depends on your motor size. A 302-306 combo typically gets a 0.68 housing. When you are doing a stroker motor, they set you up with a 0.96 housing.
Matt
bikewiz is offline
post #6 of 8 Old 06-15-2007, 04:32 PM
TurboJunky's Avatar
My stage one came with a .81 A/R exhaust.
What turbo does this housing fit? I was wondering if maybe HP used different brand turbos as often as different sized exhaust housings. Mine is a 60mm Holset.
TurboJunky is offline
post #7 of 8 Old 06-15-2007, 11:05 PM
pintoman351's Avatar
Trader Feedback: (28)
HP uses Holset turbos. They use the compressor assembly from holset and add a garret "P" trim wheel and machine a garret turbine housing to fit it.
pintoman351 is offline
post #8 of 8 Old 06-16-2007, 02:12 PM
TurboJunky's Avatar
Interesting.
If I had not already bought a Precision 76gts for my 351 swap I might have tried putting on this larger .96 housing on my current turbo to get me buy for a while.
