I'd like some opinions on new block for my turbo setup. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 05-23-2007, 04:18 AM Thread Starter
Hey everyone. I've got a 91 coupe stock block, custom turbo setup w/precision T-77 turbo, tial 40mm wategate, all supporting, fuel blah blah blah. I'm in the market for a new short block. Stocker has 120,000 miles on her and its time to retire her. I'm still undecided with what kind of/who's block to go with. I want to stay with a small block. Boost-wise I'm looking to get as much as I can out of it on pump gas, aprox 20psi and then run about 25psi on water/methanol injection. I want to be able to rev comfortably in the 7000rpm range. Not looking to go with a big lopey cam. Very mild grind. The turbo will make up for it
I contemplated on building the stock block, but then with what I want to throw at it I'll be worrying about splitting the block. Theres a lot to choose from. What would you guys suggest for what I have in mind?
CantStopSpinning is offline
post #2 of 8 Old 05-23-2007, 05:15 AM
xr8240's Avatar
Anything other than std roller block...
std 351, R302 or Dart, World - Man o war blocks...
xr8240 is offline
post #3 of 8 Old 05-23-2007, 09:12 AM
If you can get the new Boss block, then that's what I'd get.....From what I've read, all that needs to be done it the finish bore....And for $1600, that's a good deal.....
TFScoupe is offline
post #4 of 8 Old 05-23-2007, 09:36 AM
Either new Ford Boss 302 block
or the Dart Sportsman block
Both a basically the same thing, i think the boss maybe
a little cheaper.
for completely unbreakable block get the
Dart Iron Eagle, but they cost over $2k
r.barn is offline
post #5 of 8 Old 05-23-2007, 04:35 PM Thread Starter
What about a block assembly? I'd rather not have to deal with assembling the bottom end my self if I can get away with it. This is going to be street driven a lot btw.
post #6 of 8 Old 05-23-2007, 04:37 PM
DSS sells Dart and Boss302 short blocks
r.barn is offline
post #7 of 8 Old 05-24-2007, 09:06 AM
Contact DSS. They are very helpful over the telephone and distriubute/build the BOSS and Dart.
GASVT is offline
post #8 of 8 Old 05-24-2007, 10:40 AM
stephen_wehner's Avatar
I just had a Dart block built and my cousin just had a new Boss block done. Both are a great foundation for what you want. What size engine are you thinking about building?
stephen_wehner is offline
