Cooling Mod....just add Dremel. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 05-22-2007, 11:11 PM Thread Starter
OshinDivr's Avatar
Needed to get some more air to the radiator, tranny cooler and intercooler, so a buddy of mine came up with an idea to do something other than drilling some holes. We did take a 2" hole saw and cut a series of seven holes in the front bumper support to help let in as much cool air as possible. Taped off an area, cut and sanded with a dremel, then rattle canned the inside of the bumper and the support flat black. Car seemed to run consistently cooler, and cooled down alot faster between runs at the track. We also repositoned the intercooler and tranny cooler further down.
Here's some pics...
While I was taking the pics, my two year old little boy decided he wanted to suit up, and take the car for a spin...
1991 LX - Turbo 5.0
Old Combo...Stock block and heads, Turbonetics 62mm...6.78 @ 104.25 - 436rwhp/508rwtq @ 10psi
New Combo...Boss 347, TW heads, Super Victor, Cam Motion cam, Precision 78mm, Big Stuff 3, etc...
OshinDivr is offline
post #2 of 11 Old 05-22-2007, 11:57 PM
lethl-lx's Avatar
Nice !!!!
Looks Good Man !!!
91LX Vert 306 Winsor Sr. heads ,42lb inj , 70mm Accufab TB Typhoon intake ,TFS Stage 1 cam
70mm Turbo kit
lethl-lx is offline
post #3 of 11 Old 05-23-2007, 12:00 AM
Very nice!! And make sure lil man has his 10 point harness booster seat!!
ozman77 is offline
post #4 of 11 Old 05-23-2007, 07:05 AM
xr8240's Avatar
Na B.S that's you ... Lol....
xr8240 is offline
post #5 of 11 Old 05-23-2007, 11:47 AM
brian15's Avatar
ive thought about doing the same also ....
with the hellion kit how much did you move the intercooler down.... i was afriad the intercooler pipe wouldnt have enough room to move .
the fix for mine is a stalker front bumper with some trimming ....
looks good though!
brian15 is offline
post #6 of 11 Old 05-23-2007, 01:42 PM Thread Starter
OshinDivr's Avatar
I'd say it dropped down about 1.5"-2". We dropped it further down on the driver's side than the passenger side.
1991 LX - Turbo 5.0
post #7 of 11 Old 05-23-2007, 02:39 PM
Nice DirtySanchez
Never knew you were so short .....................
maybe try reinstalling your little air dam / deflector
on the bottom too.
Supposedly they really help push more air up into radiator
http://www.latemodelrestoration.com/...0%201&comp=LRS
r.barn is offline
post #8 of 11 Old 05-23-2007, 03:40 PM
Originally Posted by r.barn View Post
Nice DirtySanchez
on the bottom too.
The airdam would no longer work since the area it pushes air into it blocked by the i/c bottom and the oil cooler. And there is no place for that air to go, so basically it would just create drag. -Swampdonkey
POSSUMRIDA is offline
post #9 of 11 Old 05-23-2007, 04:06 PM
10-4
r.barn is offline
post #10 of 11 Old 05-27-2007, 01:53 AM
Might wanna round the edges on those squares... looks abrupt compared to the other holes. Very clean though.
Postalbunny is offline
post #11 of 11 Old 06-06-2007, 01:45 PM
Turbo308's Avatar
Trader Feedback: (30)
Nice DirtySanchez
on the bottom too.
I just bought mine from the local dealer and it was like ten bucks cheaper... just FYI...
1995 Mustang GT Lazer Red Convertible - E85
368 CI, PT-4788 SBF
1120 RWHP Grocery Getter!
2008 Harley Davidson VRSCDX Night Rod
Turbo308 is offline
