problems with my turbo coupe.. Expert advice needed.. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 05-16-2007, 11:30 PM Thread Starter
hey fellas, I've got a bug/misfire in my mustang that has me stumped. To start from the top, its a 93 stock bottom end, edelbrock heads, tfs cam/tfs intake, b/g headers with a mpt70,c4,42lb injectors,pmas calibrated and all the good stuff. Car was fine, we dynoed it about a month ago and it made 491 with 10 lbs of boost but was leaning out due to no fuel system. Fast forward to recent, I installed an aeromotive pump with a filter before and after, dash8 feed with dash6 return, aeromotive rails/aeromotive fuel reg.. That night I didn't get to dyno and drove home. I noticed the car would misfire when sitting at a light and thought it was loading up or something. I didn't get on it until I got back on the dyno. Today we strap the car to the dyno, make a hit. Fuel pressure was fine/ air fuel was fine/ but the car still has an intermittent misfire and feels flat. Check the timing and its the same, set at 26 total.(c16 only).. To wrap this up the car wouldn't make over 350 to the wheels today.. I'm so bumed out because im pretty mechanically inclined.. I tried another a9l and it was the same. I can only think that I have a problem with my distributor or my air flow meter.. I'm sorry for the long post but I don't want to leave anything out.. thanks and please try to help!
miamijdm is offline
post #2 of 14 Old 05-17-2007, 06:38 AM
Erich's Avatar
Just to make sure, try a leakdown or compression test just to make sure you didn't damage anything when it was lean. Or maybe a plug messed up..
What plug gap are you running? You should be at 0.025 or else you could be blowing spark out (as they say). Another thing, check your plug wires really carefully. Are you burning any with the turbo setup? Watch the motor run in the dark and look for arcing. Also make sure you are not bubbling coolant.
Just a bunch of random ideas but maybe its the wires. That would give you the misfire and it is easy to have something too close and burn up the insulation on the wire.
Erich
Erich is offline
post #3 of 14 Old 05-17-2007, 09:35 AM
Trader Feedback: (28)
x2 on the wires i had a number two cylinder wire burn up and my car was missing and popping through the tailpipes, slapped a stock plug wire on it I had laying around and it cleared right up. on my new set of wires I am going to run heat sleaves on them.
strkdblwncapri is offline
post #4 of 14 Old 05-17-2007, 09:39 AM Thread Starter
Erich
im running a plug gap of .035 same thing I was running when I dynoed 490. I have the taylor shielding on the wires so I don't think its my wires.. The car was fine when it was lean before the fuel system. I brought the boost down to 8psi that day and didn't change anything except the fuel system till now.. never even got on it..
miamijdm is offline
post #5 of 14 Old 05-17-2007, 07:15 PM
I had my autolites gapped at .037 and the car ran and dynoed fine, I put a 1000 miles on it and it started misfiring-pulled the plugs and the sharp edges of the electrode were rounded a bit, closed gap to.030 and has been fine ever since.
Just my experience.
MOOVS is offline
post #6 of 14 Old 05-17-2007, 10:57 PM Thread Starter
Just my experience.
i'll give that a shot this weekend.. I have a fresh set of plugs to put in there. thnks
miamijdm is offline
post #7 of 14 Old 05-18-2007, 12:08 PM
stephen_wehner's Avatar
sounds like either spark plugs have the wrong gap or a burnt wire
My plugs are gapped at 33
stephen_wehner is offline
post #8 of 14 Old 05-18-2007, 03:25 PM
kinda sounds like lean backfiring to me.
What did your a/f's look like on the dyno pulls???
r.barn is offline
post #9 of 14 Old 05-18-2007, 09:42 PM Thread Starter
the car hasn't been lean. It was at 11.0 all afternoon..
miamijdm is offline
post #10 of 14 Old 05-19-2007, 10:17 AM
has to be in the spark somewhere then
1. do a compression or leak down test make sure everything
is still sealing inside the engine good. ( i dont think this is your prob though )
2. Start from the plugs and work your way back to
ignition box make sure plugs, wires, dizzy, cap and rotor
coil and ignition box and everything is providing spark like it should.
and double check ALL grounds, bad grounds do wierd things too.
Sorry cant be more help ....... kinda strange problem you got here.
Let us know..............
r.barn is offline
post #11 of 14 Old 05-20-2007, 04:54 PM Thread Starter
I ordered another distributor, and im going to do just as you said.. this has to be an ignition prob.. so new cap/rotor/wires and plugs are going on this week.. I'll keep you guys updated.
miamijdm is offline
post #12 of 14 Old 05-21-2007, 06:41 AM
Erich's Avatar
With my stock ignition, I had to run 0.025 gap. 0.035 cut out as soon as there was 5 psi.
Erich
Erich is offline
post #13 of 14 Old 05-22-2007, 10:17 PM Thread Starter
Erich
im going to give that shot tomorrow. thanks
miamijdm is offline
post #14 of 14 Old 05-23-2007, 10:53 PM Thread Starter
wow.. let me start off saying THANKS to all that tried to help me out with this.. I went to the shop today and found 2 sparkplug wires burned inside the high temp sleeves that I have on my wires. I changed cap rotor plugs and wires and the mis is gone!! woohoo.. to make the night better, I dynoed it with c16 in the tank, 13 degrees of timing with the spout and 12 lbs of boost through a c4 and it made 520 whp!!!!! im stoked to say the least!!!! thanks to all again!!!!
miamijdm is offline
