downpipe ? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 05-06-2007, 02:10 PM Thread Starter
downpipe ?
i seen that some downppipes have one oxygen sensor and others have two is there a difference
thanks
pup50 is offline
post #2 of 11 Old 05-06-2007, 05:35 PM
I have 2 in mine, one for my efi system and one to be used while at dyno so that they could also place there own wideband sensor.
79pacecar is offline
post #3 of 11 Old 05-06-2007, 05:42 PM
TurboJunky's Avatar
Mine has two because it replaces the stock duel exhaust which had one in each pipe. Two sensors keeps the computer happy.
TurboJunky is offline
post #4 of 11 Old 05-06-2007, 06:11 PM
Trader Feedback: (30)
I have 3 and it is a B&G kit. 2 are for the o2 sensors, the other 1 is for a wideband meter.
-'90 Mustang LX Coupe 5.0 SSP. 83 DSO US Gov't Issue. H/C/I Track toy
93Krwy is offline
post #5 of 11 Old 05-06-2007, 07:13 PM Thread Starter
so it would be worth it to add some sensors ports
pup50 is offline
post #6 of 11 Old 05-06-2007, 07:23 PM
staticstang's Avatar
I've got 3......2 for stock narrow band 02 sensors and 1 for my wideband sensor.
staticstang is offline
post #7 of 11 Old 05-06-2007, 09:07 PM
1foxbody32's Avatar
Trader Feedback: (26)
Like a couple other people mentioned in this thread when I do mine its going to be 3 also.
SIRACING.NET
1foxbody32 is offline
post #8 of 11 Old 05-06-2007, 10:47 PM
Blackfive0's Avatar
Trader Feedback: (62)
I too will have 3. 2 are for the stock ones and the other is for my LM-1.
Blackfive0 is offline
post #9 of 11 Old 05-07-2007, 09:07 AM
bikewiz's Avatar
Trader Feedback: (18)
I have the HP kit like BlackFiveO and I too have 2 stock O2s and then I welded in a bung for my DynoJet Wideband.
Matt
bikewiz is offline
post #10 of 11 Old 05-07-2007, 12:19 PM
smurfmobile8586's Avatar
I think that i will add another onf for the dyno then for a total of 3
smurfmobile8586 is offline
post #11 of 11 Old 05-07-2007, 05:20 PM Thread Starter
ok so i guess i have to add a couple of bungs how far apart should they be
pup50 is offline
