Some help with a fuel cell and pump - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 04-21-2007, 10:13 AM Thread Starter
Got alot of the part together to finally get this project underway except afew peices here and there. One of these is to figure out which fuel cell and pump setup is best for my application. It's a 98 cobra and I'm looking for around a 10 gallon or so cell for a street application. I was thinking about going with a Ford GT style pump setup. What i am unsure of is are there tanks out there that you guys would recommend? The car should make alittle over the 1k mark with the turbo setup, once complete so the pump would need to support this which from what i've read and seen the Ford GT pump should have little issue. Will there need to be any special modification done to an aftermarket cell to support the pump?
Thanks for your help
jcr1982 is offline
