oil pan - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 04-16-2007, 08:07 PM Thread Starter
oil pan
were is the best place to get a Oil Pan Fitting Bung. I just want a fitting I can weld to the oil pan itself so I don't have to worry about leaks. Also what size should I run I have hear -10 or -8 for return and -4 for supply is that right?
stang393 is offline
post #2 of 4 Old 04-16-2007, 09:15 PM
fred50stang's Avatar
Hose and tube manufacturer. Look for something along the lines of "rubber specialties", or "hydraulic" type of stuff. We have a place here in pensacola that sells all kinds of neat stuff. Called "rubber specialties".
You cant use the stuff at the hardware store because its brass. But I have never had any problems with leaking bung fittings in my oil pans. Just the Canton oil pan itself(pos!).
fred50stang is offline
post #3 of 4 Old 04-17-2007, 07:29 AM
Erich's Avatar
I got weld on AN fittings from Sephs fabrication. You want to use -10AN for a drain. -3AN for a feed (or the smallest brakeline you can find).
Erich
Erich is offline
post #4 of 4 Old 04-22-2007, 01:16 AM
SilverFox's Avatar
Yeah, you'll need a 10an male bung. Summit and Jegs both carry them. Summit has their own brand, you'll find them on the same page as the fuel cells. Jegs carries them with the Moroso name. Both types are aluminum fittings.
New Combo.....1985 notch, 331, T-76GTSH, C4, track numbers soon.
SilverFox is offline
