need some advice on max CR for 10# of boost - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 04-13-2007, 02:11 PM Thread Starter
I thought I researched all of this enough a year ago when I started buying parts, but things have changed a bit, so here I am asking for help.
I'm trying to assemble a Dart 347 - 4.125" x 3.25" with Ross pistons made for boost, and with a 14.7cc dish. The ported AFR 185 head chamber volume I was counting on was going to be around 62-65 cc, but they "came out" 55cc! That gives me a 10:1 CR instead of 9:1.
So the question is, can I run enough boost at 10:1 to even make a turbo installation worth the trouble, or should I get the compression ratio down at all costs for turbo use? I will be using an AEM EMS which if properly set up will give good control over mixture and timing, but I know you can't just drown the motor in gas to make up for possible detonation.
I'm almost considering going n/a with the 10:1 CR. As you can see I don't have clearly defined HP requirements. I just want one wicked street car.
I seriously appreciate any thoughts.
JimS is offline
post #2 of 10 Old 04-14-2007, 09:57 AM
Gabe's Avatar
I would not even waste your time with a turbo setup with that high compression. I had the same problem with my old set up. 10 to1 in a 306. I ran 11.2's all motor with a carb. Had to sell motor and go with a stock 302 and turbo. Hopping to get into the 10's. I just think turbos are so cool. You should be about to run ten easily with the 347. You will need a bigger head though. 2.05 valve. 100 shot of nos and u r in the 9's. With carb setup. Efi, a little harder to tune and more money.
Gabe Davila
93 Lime Green Coupe RIP 11.2 @127 all motor
95 Turbocharged Cobra
90 Titanium coupe
Gabe is offline
post #3 of 10 Old 04-14-2007, 09:59 AM
Gabe's Avatar
personnally I think I would get a different head with bigger combustion chambers to get down the CR. With Cometic gaskets
Gabe Davila
90 Titanium coupe
Gabe is offline
post #4 of 10 Old 04-14-2007, 01:16 PM
i got 9.5/1 compression and 10# of boost and just trashed my motor look at the above post 2nd day out lifted heads
sprayed88 is offline
post #5 of 10 Old 04-14-2007, 03:00 PM
leave the compression alone and simply run
A.) less boost
B.) higher octane fuel
C.) less timing
D.) All or some of the above
the more efficient the engine is pre-boost the more efficient the application of forced induction is.
example: http://www.musclemustangfastfords.co...ression_ratio/
Pope is offline
post #6 of 10 Old 04-15-2007, 09:48 AM
xr8240's Avatar
Seeing you are still assembling this engine?? I suggest getting pistons with bigger dish...
xr8240 is offline
post #7 of 10 Old 04-15-2007, 10:35 AM Thread Starter
I know you are suggesting different pistons, but the machine shop suggested cutting 10cc from the pistons.
I have a lot of questions about doing that.
Will removing ~10cc of material leave the top of the piston thin in areas?
How does a person decide where to remove material?
Will removing another ~10cc of material adversely affect the way the gas burns in the chamber? Quench area?
What does removing material do to the balance of my internals?
Should I really be tampering with Ross designed pistons because they missed on the heads?
JimS is offline
post #8 of 10 Old 04-15-2007, 05:39 PM
I used to run 22psi with 10:1 cr. i now run (safely, with the wastegate spring maxed) 9.7:1 with 26psi. i'd be happy to run 30psi too. and i will. it's all in the tune. so tune it well and don't worry so much.
ANYONE who says you can't run 10:1 has NEVER tried to build a motor to do it... they are just repeating what they've heard from other people who are AFRAID. It is NOT a response based on experience.
my .02...
JD
jdell is offline
post #9 of 10 Old 04-15-2007, 08:30 PM Thread Starter
my .02...
JD
Assuming I can learn the AEM computer and get it tuned before I hurt the motor, I will have lots of control. I plan to install the computer once I get the 347 running n/a.
But.... I was afraid that you can richen the mixture only so far, and pull only so much timing.
Assuming you are fuel injected, what are you using for engine control?
How rich are you running and how much timing?
JimS is offline
post #10 of 10 Old 04-15-2007, 11:35 PM
I run an AEM already. the trick: get EGT sensors. I have two. it helps a LOT.
jdell is offline
