need a shortblock that will handle boost - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 17 Old 04-11-2007, 05:31 PM Thread Starter
turbodstang's Avatar
hey guys i have a turbo'd notch. here are the details on it
Turbo System:
Precision 66mm t-04 housing, .86 a/r exhaust, Tial 50mm blowoff valve, Tial 44mm wastegate, turbonetics manual boost controller, ebay special bar-type intercooler
Engine and Management System:
Stock ecm (A9L) untuned! stock 88' shortblock w/ main girdle, stock 88' camshaft, AFR 185's, Lunati 1.6 rocker arms
Induction and Fuel:
Victor 5.0 intake, 65mm Ford Motorsport T-body, stock tank w/ a1000 pump , Aeromotive rails and Motorsport 42lb. injectors, aeromotive regulator.
Ignition and Exhaust:
MSD digital 6, MSD Blaster coil
Tranny and rear:
8.8 w/3:73 gears, SVO cover, Strange 33-spline axles, Strange spool, Motorsport alum. driveshaft, Tremec 3550, Lakewood SFI bellhousing, SPEC stage 3 clutch.
as you can see it has a stock block in it along with a stock cam and untuned ecu
right now at 9 psi the car runs 10.61 at 134mph 532 rwhp this is the conservitive tune
the car can be dial'd up to 14 psi but i dont want to because the stock blocks arnt meant to handle that amont of power...heck im already pushin it at 9 psi
question is where should i go to get a good short block and what is the best combo to go with i.e...306,331,347
is there a shop that primarily deals with turbo cars
also the block is going to need to support 900 rwhp bigger turbo will be coming this winter
turbodstang is offline
post #2 of 17 Old 04-11-2007, 06:15 PM
staticstang's Avatar
In plan on going w/ a dart blocked 331 combo(due to the better rod ratio compared to the 347). There are several good shops that build strong engines. From what I have heard AD Performance can give you a good bang for your buck. I currently am running a stock blocked DSS 306, which has been good to me, so I might see what kind of deal those guys can give me on a dart blocked setup.
staticstang is offline
post #3 of 17 Old 04-11-2007, 06:27 PM Thread Starter
i have afr 185's would they be able to be switched over to a 331??
post #4 of 17 Old 04-11-2007, 07:21 PM
Yes.
post #5 of 17 Old 04-11-2007, 10:38 PM
You're kidding right?? I think that you're just trolling through here.....Someone that can build their own turbo kit would know that AFR heads will work on a 331 as would a 302, 306, or 347 being that those are all based on the 8.2 deck block......I think that the 134 trap speed is just a tad high for mid 10's.....Especially with 3.73's......And how does that 10 spline input shaft not twist under 532rwhp??
TFScoupe is offline
post #6 of 17 Old 04-11-2007, 11:31 PM Thread Starter
whoops...sorry i just copied and pasted all that from the add i bought the car from
as i said this is my first ford
always had camaros before
post #7 of 17 Old 04-11-2007, 11:35 PM Thread Starter
i dont know man the car has been running like this for awhile now i guess
heres the add for the car
Best time as of 2-7-07: 10.61 at 134, 17" DR
702rwhp / 739 rwtq at 14psi, 93 octane
Current Combo:
Turbo System:
Precision 66mm t-04 housing, .86 a/r exhaust, turbo system built by me, Tial 50mm blowoff valve, Tial 44mm wastegate, turbonetics manual boost controller, ebay special bar-type intercooler
Induction and Fuel:
Victor 5.0 intake, 65mm Ford Motorsport T-body, stock tank w/ 255lph in-tank and 255lph pusher pump (Vortech), Aeromotive rails and Motorsport 42lb. injectors, aeromotive regulator.
Tranny and rear:
Front Suspension:
UPR K-member with A-arms and coil overs, Lakewood 90/10 struts, Motorsport caster camber plates
Rear Suspension:
Factory 5 upper/lower control arms, welded torque boxes, stock 88' shocks
Tires and rims:
Bogart Drag-on-Fly Stars, Mickey Thompson 275/60/R15 Body:
Stock 88' body w/ 2 1/2" cowl hood
Future plans:
Put a bar in the car so I dont get kicked anymore, up the boost to 18psi, run race gas and hopefully go 140mph!
Background:
Car went 10.61at 134mph on 11psi (1.87 60ft) with a mixture of 91 octane and avfuel on the Mickey Thompson tires.....the car has some more in it because I have not hooked up the retard function through the digital box.....I wanna leave on boost and run it into the nines on a stock shortblock and drive it back home!
post #8 of 17 Old 04-12-2007, 12:27 AM
Current Combo:
Turbo System:
Induction and Fuel:
Tranny and rear:
Front Suspension:
Rear Suspension:
Tires and rims:
Future plans:
Background:
Someone is yanking your chain........NO WAY that a stock block will hold 702rwhp, not even for one dyno pull...Even if the block was filled...And second, a 66mm turbo w/ .86 housing WILL NOT make that kind of power.....My Precision T70 won't even make 700rwhp.....Since you used to be a chevy guy, I see now why for the head question in the earlier post.......
TFScoupe is offline
post #9 of 17 Old 04-12-2007, 03:04 AM
1foxbody32's Avatar
Trader Feedback: (26)
damn some weird things in here lol
SIRACING.NET
1foxbody32 is offline
post #10 of 17 Old 04-12-2007, 10:21 AM
stephen_wehner's Avatar
To answer your question, a Dart or Boss block
stephen_wehner is offline
post #11 of 17 Old 04-12-2007, 11:42 PM
1foxbody32's Avatar
Dart is the way to go
SIRACING.NET
post #12 of 17 Old 08-30-2007, 03:07 PM
i dont know if the guys is just bul####ting and he realy juste boought the car but heres the car feature car on turbomustang forum
http://www.theturboforums.com/featur...sdeegfeb07.php
lov2xlr8 is offline
post #13 of 17 Old 08-30-2007, 03:11 PM
why not there 9sec stock shortblock car whit t70 .68ar
there even a 9sec stock longblock car
stock explorer motor 636rwhp aint far from 702rwhp
there a vid of a turbo coupe stock shortblock gt40 heads 15psi ish 6??rwhp lasted 2 weeks but hey it still lasted more than a dyno pull
lov2xlr8 is offline
post #14 of 17 Old 08-30-2007, 11:27 PM
jturmanator's Avatar
DSS 331
jturmanator is offline
post #15 of 17 Old 09-07-2007, 09:50 AM Thread Starter
WOW old thread.....i actually just finished my build
i went 331 Boss block/8:7.1 static comp/rollerized C4/PT78GTS turbo
hoping for low 9's in the near future!!!!!!!!!!!!!!
post #16 of 17 Old 09-07-2007, 11:27 AM
Mikes88Stang's Avatar
Pics!?
--Mike K.
[email protected] W/ old, tired motor.
Current setup: A big hairdryer and supporting mods. Spetter tuned.
Mikes88Stang is offline
post #17 of 17 Old 09-07-2007, 11:47 AM
montelius's Avatar
Trader Feedback: (31)
FYI, I believe the 7 was a typo. It's suppose to be a 5.
Luke M.
montelius is offline
