Speed Pro Piston Rings R9343-need advice - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 04-11-2007, 03:51 PM Thread Starter
Hello. I am building a turbo 351W. MP-T70 Turbo. HP goals 550-600rwhp. I am using TRW/SpeedPro L2446F-30 low compression forged pistons. Heads are AFR 205's with 69cc chambers. My question is this. Will I be ok with the rings in the title? They have a ductile iron top ring, cast iron second ring, and stainless steel std. tension oil control ring. They are file fit and the ring size is .035. So will these be a good match to my combo? Also, how do I find out how much to file from the rings? Thanks a lot guys/gals.
Mike Reese
2005 Mustang GT
mrmonk7663 is offline
post #2 of 3 Old 04-15-2007, 07:53 PM
xr8240's Avatar
Place the rings in bore about 2 inches down then measure ring gap with feeler guage.. Boosted engines require extra ring gap.
Mine are gapped at .028 top and .030 second ring...
You can run yours tighter at your power level....
Rings are ok also at your power level....
xr8240 is offline
post #3 of 3 Old 04-18-2007, 05:10 PM Thread Starter
Thanks!!!
2005 Mustang GT
